HVAC Threw these DIC Codes
Old Aug 13, 2003 | 08:06 PM
Garibaldi's Avatar
Garibaldi
Default HVAC Threw these DIC Codes
B1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
The only thing I've noticed is that I can't get the panel vents and floor vents to work simultaneously. Any thoughts?
Regards,
Garibaldi
Old Aug 14, 2003 | 01:31 AM
mapman's Avatar
mapman
Default Re: HVAC Threw these DIC Codes (Garibaldi)
The only thing I've noticed is that I can't get the panel vents and floor vents to work simultaneously. Any thoughts? .....
The HVAC control assembly is a non class 2 device (interface is between the operator and the HVAC system). Therefore, I don't believe the loss of communications DTC you listed have any thing to do with the panel/floor vent problem.
The B1016 code - is that correct, or was it "U1016". I cannot find a "B"1016 DTC.
Old Aug 14, 2003 | 07:44 AM
Garibaldi's Avatar
Garibaldi
Default Re: HVAC Threw these DIC Codes (mapman)
The B1016 code - is that correct, or was it "U1016". I cannot find a "B"1016 DTC. [/QUOTE]
You're right. The list I copied and pasted the descriptions from listed it as "B1016."
Regards,
Garibaldi
Old Aug 14, 2003 | 08:24 PM
mapman's Avatar
mapman
Regards,
Garibaldi
B1016, I was looking at my 2003 service manual and that code isn't listed. I saw where it was included in an earlier list - I guess GM changes things now and then. :)
To HVAC Threw these DIC Codes
