Electrical Problem with turn signals
Old Aug 14, 2003 | 08:15 AM
Kexec's Avatar
Kexec
Default Electrical Problem with turn signals
My 2000 FRC has a electrical problem that affects the turn signals form time to time. Ocassionally, I will not have turn signals at all. It happens when I am driving, but not all the time. After the car sits for a while the turn signals work again.
Any ideas what the problem might be?
:steering:
Old Aug 14, 2003 | 08:40 AM
Turbo5's Avatar
Turbo5
Default Re: Electrical Problem with turn signals (Kexec)
Its time to install a new blinker relay. Cost $38.02 installation cost $150. Sorry about that. This seems to be a fairly common problem.
Turbo5 :eek: :eek: :eek:
Old Aug 14, 2003 | 01:08 PM
Kexec's Avatar
Kexec
Default Re: Electrical Problem with turn signals (Turbo5)
Oh Boy!
I assume with that amount of labor, the relay is in some odd place. Do you know where it is located?
:steering:
Old Aug 14, 2003 | 02:39 PM
Turbo5's Avatar
Turbo5
It's located behind the dash board.
Turbo5 :rolleyes:
Old Aug 14, 2003 | 03:10 PM
Trey395's Avatar
Trey395
Next time it doesn't work, try barely pushing the emergency blinkers button, that fixes mine all the time...
Old Aug 14, 2003 | 10:22 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: Electrical Problem with turn signals (Trey395)
If it's not the relay, it may be the turn signal switch. I had no rear brake lights on the right side. Everything else worked. Bulbs were good. The relay is cheaper than the turn signal switch, so check that first. I've seen a bad turn signal switch act in wierd ways. Some guys have turn signal problems, others have brake light problems. Seems to be fairly common also. Good luck- Scott
Old Aug 14, 2003 | 10:53 PM
Kexec's Avatar
Kexec
Thanks, I will try this the next time the turn signals go on the blink ( no pun intended). Kansas City is home for me so its good to get a useful tip from the home team.
:steering:
Old Aug 14, 2003 | 11:37 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
When my car was in the shop the column locked on them so they did the recall. Now it does exactly what yours is doing. The blinkers work about half the time. The dealer said it was the relay which is part of the hazard swithc. You have to take the dash off. Mine's under warranty, but I didn't want to stick it back in the shop. Turn on the blinker and if it doesn't work then push on the hazards then take them off. I'm going to try the barely touching the hazard switch method mentioned above next time it happens.
:cheers:
To Electrical Problem with turn signals
