Decarbonization process now check engine light.
Old Aug 14, 2003 | 12:16 PM
RoadVette's Avatar
RoadVette
Default Decarbonization process now check engine light.
Hey Guys, quick question. Followed the decarb procedure to the T. Waited 12 hours, started engine, now check engine light is coming on. Is this normal? I definately placed top engine cleaner in the correct hole. Thanks for input!
Old Aug 14, 2003 | 12:42 PM
Patches's Avatar
Patches
Default Re: Decarbonization process now check engine light. (RoadVette)
First go in and check for codes. Post any codes here so we can see what you got.
:cheers:
Old Aug 14, 2003 | 12:47 PM
SFVetteman's Avatar
SFVetteman
In case you don't know how to check the codes, this will tell you how:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Aug 14, 2003 | 12:53 PM
RskyBns's Avatar
RskyBns
It is normal after you start the car and get all the cleaner out of the motor for the check engine and O2 light to come on. Shouldn't last long. If it is prolonged "after a couple drives" then there is something else going on.
Old Aug 14, 2003 | 01:07 PM
blue98coupe's Avatar
blue98coupe
Default Re: Decarbonization process now check engine light. (RskyBns)
same thing happened to mine after I did the decarb ,02 sensors went nuts .Just clear out the codes on your DIC and it should be good to go .Make sure you change that oil too ,P.S did you neighbors like the cloud of smoke :lol: I left a trail of smoke for miles
Old Aug 14, 2003 | 01:15 PM
RoadVette's Avatar
RoadVette
Checked for codes, no codes. I will change the oil and run the car a little longer. I will post if anymore questions.
Thanks for the input-I love you guys, but don't tell my wife, she has been waiting to hear those words for quite some time. :)
Old Aug 14, 2003 | 08:52 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The PCM will detect the missfires from the cleaner passing through,you should be good to go :thumbs:
Old Aug 15, 2003 | 02:53 PM
sbkim's Avatar
sbkim
Default Re: Decarbonization process now check engine light. (C-5 TECH)
I am getting ready to do this. Have you noticed much differenece afterwards?
thanks
Old Aug 15, 2003 | 10:13 PM
Bugster57's Avatar
Bugster57
Seems I remember having the same issue, it was due to idle RPM being too low I believe.
Engine heat cycle cleared the problem. You got to think about just what the decarb process does and you'll understand how it can drive the engine management sensors nuts for awhile.
I bet it'll clear on it's own. Seen it several times before.
To Decarbonization process now check engine light.
