climate control module- dual zone
Old Aug 14, 2003 | 04:07 PM
skidmarc's Avatar
skidmarc
Default climate control module- dual zone
is this plug n play to convert manual ac/ or non dual zone??? or is additional equipment needed other than the module itself???
thanks guys
Old Aug 14, 2003 | 04:13 PM
gonbad's Avatar
gonbad
Default Re: climate control module- dual zone (skidmarc)
You cannot retrofit a non dual zone to a dual zone by just adding the dual zone controler. It would take aditional wire harness, sensors, actuators, vacuum lines etc. I bought my new controler from a guy who was going to try this and decided wisely that this would be a giant PIA.
Old Aug 14, 2003 | 04:20 PM
ROD BROWN's Avatar
ROD BROWN
I personally don't think the dual zone A/C control is worth the money.A cool interior is al the comfort you need.I have the dual zone A/C and I really don't think its all that its cracked up to be.Just a laymans opinion. :chevy :chevy :flag :chevy :chevy
Old Aug 14, 2003 | 06:18 PM
JC in XTC5's Avatar
JC in XTC5
Default Re: climate control module- dual zone (ROD BROWN)
As :iagree:
Manual system uses vacuum actuators to move flow gates, etc. , Dual Zone uses eletronic actuators and has a different setup.
Old Aug 15, 2003 | 12:59 AM
molon labe's Avatar
molon labe
don't waste your time and money on it.
i've got it, and don't think its anything special at all. just something for the wife to play with while i drive.
[Modified by tattooed, 12:00 AM 8/15/2003]
Old Aug 15, 2003 | 09:10 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I agree that dual zone control is a waste in a 2 seater car, but it IS nice to be able to set the temp and forget about it. :yesnod:
Tom
Old Aug 16, 2003 | 03:39 PM
Vampyre's Avatar
Vampyre
Default Re: climate control module- dual zone (TCW)
Hmmm, I think it depends on how you use the car, if you drive alone alot it is a waste of money.
I have the dual zone A/C and my wife does find it nice, I like the car cabin temp around 67 degrees. my wife likes it warmer and almost always adjusts her side for warmer air.
Old Aug 16, 2003 | 06:15 PM
Kent1999's Avatar
Kent1999
Is there supposed to be any visual indicator showing the Dual Zone is active (besides the passenger **** being turned)?
On other Dual Zone controllers on other GM cars -- when you turn the passenger ****, the display changes to indicate your dual zone setting.
On my C5, it's hard to determine from the driver's seat if the dual zone is even doing anything.
To climate control module- dual zone
