Ported/Polished TBs, What Does....
Old Aug 15, 2003 | 04:06 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Ported/Polished TBs, What Does....
...sealing off the fresh air port of the Throttle Body accomplish?
Curious as I'm about set to start porting and polishing my TB :cheers:
Old Aug 15, 2003 | 04:31 PM
chuckster's Avatar
chuckster
Default Re: Ported/Polished TBs, What Does.... (Mean Blue Z02)
Mark, I sealed off my port for 2 reasons..
1. I did not want the PCV cutout causing turbulence inside the TB
2. I felt that fast rushing air going past the PCV opening could potentially cause an unwanted vacuum and start sucking oil contaminated air back through the throttle body..
The only reason GM tapped off that spot in the TB was they need "filtered" air to run through the crankcase.. This was the only logical place to put it without the added cost of adding a filter like I did or rerouting the PCV hoses up to the airbox.
Here is an example of the Vacuum..Shaner fills the PCV cavity then drills a hole in it.. ok..
Stick a soda straw in a can of coke.. Then take compessed air and shoot it across the top of the straw...
Coke will immediately be sucked right up the straw and out.. I did not want that to occur at WOT
[Modified by chuckster, 4:34 PM 8/15/2003]
Old Aug 15, 2003 | 04:34 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Ported/Polished TBs, What Does.... (chuckster)
hmmmm, sounds pretty logical to me :D
Old Aug 16, 2003 | 07:18 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
What Chuckster said :) :)
I drilled a hole and have checked and found no OIL inside TB even with Blower. Before MOD there was a small amount but nothing to be alarmed about.
george
Old Aug 16, 2003 | 08:44 PM
GENERAL ST's Avatar
GENERAL ST
Default Re: Ported/Polished TBs, What Does.... (Black_Magic)
This is a guaranteed ticket into that Hall Of Fame .Keep up the good work
We are all counting on you.Set a good example!!!Dont tear up too much of that track others want to race too!! :seeya :flag :flag :flag :chevy :chevy
Old Aug 27, 2003 | 06:16 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Ported/Polished TBs, What Does.... (GENERAL ST)
So what about polishing the TB? Has anyone done that themselves? Results?
To Ported/Polished TBs, What Does....
