Active handling?????
Old Aug 16, 2003 | 04:39 PM
ITSovr4U's Avatar
ITSovr4U
Default Active handling?????
Why does my car say active handling warming up???? Its 80 degrees out, and it never did this before. Please help. Thanks, John :seeya
Old Aug 16, 2003 | 06:32 PM
atlantavette's Avatar
atlantavette
Default Re: Active handling????? (ITSovr4U)
my car has flashed that message maybe twice in a year..and it was hot out both times as well. i was wondering the same thing
Old Aug 17, 2003 | 09:34 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
"warming" simply means that the ABS is performing a self function test..."warm-up complete" means the test is completed and past...This happens when traveling under a certain speed for an extended period,such as in a parking garage :yesnod:
Old Aug 17, 2003 | 02:18 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
I have just gone through all this myself. If it says complete fairly rapidly, the manual says it is normal, although I never expericed it before my incident.
It turns out for me, that I had a bad wiring harness going to the IAT sensor. These sensors are all communicating so when this was causing errors, it gave me active handling warming up, and wouldn't go away even though it has nothing to do with active handling.
A very knowledgeable service manager at a local dealership fixed this for $225 out the door. I was throwing high voltage codes for the IAT sensor as well as lost communication.
All fixed now. :hurray:
To Active handling?????
