Supposedly a bolt on swap, but I am still having a heck of a time getting the tips properly aligned. :banghead: This probelm has been reported by a few CF guys, but not sure of the proper fix.
I was able to reuse my gaskets.
If you intend on doing it without lift, be prepared to jack the rear end really high... I think we had 25 inches under the crossmember. The left side needs a little less.
Make sure you buy a sytem that is "uncut." Some guys get frustrated and cut the flange off the end to get them out... that is an expensive short cut.
