Anyone running a reverse split cam in a daily driven A4???
Old Aug 16, 2003 | 11:20 PM
los7883's Avatar
los7883
Default Anyone running a reverse split cam in a daily driven A4???
Anyone had any experience with a reverse-split cam in a A4? The ones that caught my eye were:
228/224 .588"/.581" 112 LSA
227/224 .569"/.563" 114 LSA
Car has to be able to pass the sniffer test too. I'm starting to think that my TR220/220 isn't aggressive enough...what could I expect to pick up with one of these cams (above the cam I have now). Reason why I was looking at the reverse split is because one of these days I would like to get the 5.3L Stage II heads...which from what I hear favor the reverse split due to the flow characteristics of the exhaust side...whatcha' think???
[Modified by los7883, 10:20 PM 8/16/2003]
Old Aug 17, 2003 | 10:45 AM
vstella's Avatar
vstella
Default Re: Anyone running a reverse split cam in a daily driven A4??? (los7883)
Not a reverse split but nasty just the same....232/236-575/578-112 from Lunati...Check out my CF homepage for a listen of the cam...:D
Old Aug 17, 2003 | 06:53 PM
los7883's Avatar
los7883
Default Re: Anyone running a reverse split cam in a daily driven A4??? (vstella)
Gaww dang...that's a big cam. I saw on your webpage that you used to have a 226/226/554-114 cam...how did you like it? What would the hp difference be between a 112 and 114 LSA? Better tq down low?
Old Aug 17, 2003 | 10:01 PM
vstella's Avatar
vstella
Gobs of TQ....Right now I'm at 490 RWT rom 3500 rpms...My earler cam really very streetable as well...just wanted a little more agressive grind when I stroked the engine.... :yesnod: :thumbs:
To Anyone running a reverse split cam in a daily driven A4???
