HELP OIL PRESURE GAGE
Old Aug 17, 2003 | 09:28 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default HELP OIL PRESURE GAGE
took my car to thje dealer yesterday. it said low oil so they gave me a oil change. but the low oil did not go away on the dic. so the c5 tech said i probally have a bad sensor in the oil pan. so he replaced it 2 oil changes later it went away with changing the sensor. now the oil presure gage goes to 80 psi at wot. this is not right anyone had this happen before and thanks in advance. :confused: :mad
Old Aug 17, 2003 | 11:13 PM
davidfarmer's Avatar
davidfarmer
Default Re: HELP OIL PRESURE GAGE (stunna)
was your dic reading "low oil" or "low oil pressue", as the two should not be related, in general.
80psi is high for a stock engine, but not dangerous. If the oil fluctuates from 20-80, you are fine. Up to a point, high pressure is a good thing.
Dave
Old Aug 17, 2003 | 11:31 PM
CAPN17's Avatar
CAPN17
Default Re: HELP OIL PRESURE GAGE (davidfarmer)
Oil pressure that blows the dip stick out is a bad thing. WHen I am pushing the Z she hits 70 to 80 lbs. on occasion.
Old Aug 18, 2003 | 07:05 AM
Carbotech Adam
Supporting Vendor
it said low oil not low oil presure. i have never noticed the presure gage go that high. i dont know if these are related problems or not. :confused:
To HELP OIL PRESURE GAGE
