Header wrap... any reason to do it?
Old Aug 18, 2003 | 01:21 PM
schpodie's Avatar
schpodie
Default Header wrap... any reason to do it?
Hi all, pretty new to the forum and new to vettes. I am planning on purchasing some LT headers very soon and understand that normally (in the world of V8s) there are reasons for wrapping your headers. If I recall correctly the reasons are 1) keep exhaust heat in to lower underhood temps 2) keep exhaust hot for better exhaust gas velocity. I think there may be downsides such as metal fatigue etc but being new to the world of v8's and displacement I just don't know.
Has anyone tried wrapping headers on their C5? Is it a good idea?
Thanks!
Old Aug 18, 2003 | 01:24 PM
JERRYC's Avatar
JERRYC
Default Re: Header wrap... any reason to do it? (schpodie)
From what I have heard this is useless on the newer headers because most of them are coated inside & out & the coating has the same effect as wrapping.
Old Aug 18, 2003 | 01:38 PM
schpodie's Avatar
schpodie
Default Re: Header wrap... any reason to do it? (JERRYC)
What about the new LG pro(duction) LTs? I think they are stainless and uncoated...?
Old Aug 18, 2003 | 02:16 PM
c5chris's Avatar
c5chris
I would not waste my money on wraps to keep temps down. I would go to ceramic coating or nothing at all for stainless steel. Heat wraps are marginal during use coz i used them for my other cars and they have the same underhood temps as without. Well maybe a degree lower, big deal.
The bad thing is that they hold moisture and being on the headers is a no-no. If you keep your Vette out, in a cold morning they are damp. Moisture promotes corrosion, enuff said.
Old Aug 18, 2003 | 02:46 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Header wrap... any reason to do it? (c5chris)
I wouldn't bother with header wrap, especially on mild steel headers because the moisture that gathers in the wrap can cause some heavy corosion.
To Header wrap... any reason to do it?
