for those with ati dampner
Old Aug 19, 2003 | 12:36 AM
2014stingrayjoe's Avatar
2014stingrayjoe
Default for those with ati dampner
seems that under hard stopping, the bolt heads are hitting the rack and pinion. have taken the washers out, but still doing it. any one else had this problem and any cure? thanks, joe
Old Aug 19, 2003 | 04:45 PM
2014stingrayjoe
Default Re: for those with ati dampner (ADMIRAL JOE)
nobody is having this trouble but me????????????
Old Aug 19, 2003 | 04:46 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I have had them back out. You need to use a few drops of red Locktight. :seeya
Old Aug 19, 2003 | 04:52 PM
davidfarmer's Avatar
davidfarmer
Default Re: for those with ati dampner (CHRIS NJ C5)
You need to remove the hex head bolts and ONLY use the counter sunk bolts. Also, I would suggest switching to harder engine/diff mounts, like those from VBP.
You're entire drivetrain is moving forward under braking. I had the same trouble until I removed the redundant bolts. Don't forget the loctite on the bolts you use, and don't overtorque. Also, make sure the loctite has plenty of time to dry.
Dave
To for those with ati dampner
