re-locating mat sensor 1998 c-5
Old Aug 19, 2003 | 05:46 PM
c5-pacecar's Avatar
c5-pacecar
Default re-locating mat sensor 1998 c-5
has anyone relocated there mat sensor to opposite side of air bridge?and if so, did it help with ignition timing ? meaning was there a noticeable increase in power band,especially in low end? any info would be appreciated :confused:
Old Aug 19, 2003 | 06:44 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: re-locating mat sensor 1998 c-5 (c5-pacecar)
Are you talking about the recalibrated MAT sensor? If so, all it does is fool the computer into thinking it is 20 degrees cooler, thus tricking the PCM to allow for more timing. The mod works OK (can't say how well) but is not necessary if you plan to do LS1 edit.
Old Aug 19, 2003 | 07:53 PM
c5-pacecar's Avatar
c5-pacecar
Default Re: re-locating mat sensor 1998 c-5 (Jeff Jeff)
i am replacing the air bridge with carbon fiber,i am trying to deside which side of bridge to drill ,i am unsure what you mean by ls1 edit,could you explain?thanx
Old Aug 19, 2003 | 08:26 PM
Jeff Jeff's Avatar
Jeff Jeff
I don't think it matters what side you drill. Mine is on the drivers side. I can't see switching sides doing anything to measure the intake air temperature differently.
The recalibrated (which is also relocated) MAT sensor "tricks" the computer into thinking it is colder. This results in different timing tables used in the PCM which incorporate more timing. You can achieve the same thing with LS1 edit by changing the timing tables.
Hopefully this helps.
Old Aug 19, 2003 | 08:31 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
I have it installed, but you won't notice any SOTP improvement. I did it simply because I wanted the MAT sensor as far forward on the airbridge as possible to sense the cooler air. So when you do drill a hole, just make it as close to the MAF as you can. 2001 and later C5's have the MAT sensor in the MAF itself for this very reason. If you are using the stock airbridge, there is already a flat spot forward that you can use, but if you are using an aftermarket powerduct, it doesn't matter where you drill the hole.
Old Aug 19, 2003 | 08:34 PM
c5-pacecar's Avatar
c5-pacecar
understood, thankyou! jeff jeff
Old Aug 20, 2003 | 11:20 AM
cscollis's Avatar
cscollis
I have a tricker that makes it 75 degrees always. Works great below 95 degrees but causes knock over 95. Over 95 I just put the iat sensor in the air bridge for correct readings. Adds 2 degrees of timing when its 90 outside with no knock(humidity helps).
To re-locating mat sensor 1998 c-5
