Nope the 02 sensors only work with the 02 and up PCM's.
You need to find 02 wheels that have been machined to accept the 97-99 sensors. Most of the aftermarket 02 wheels come already machined. Check with the wheel vendor before you purchase!
Best of luck to ya,
Tim
all you have to do is transfer the sensors from your 99 wheels to the polished ones. make sure to use new o-rings (for the sensors) when you do the switch.
note: if you put the sensors back to their original corners you won't have to reprogram them.
