C5 Front Rotors and Pads
Old Aug 21, 2003 | 10:55 AM
williammease's Avatar
williammease
Default C5 Front Rotors and Pads
My street driven '98 C5 has the original pads and rotors and I think I have a common problem occurring-warped rotors. Should I try using the GM drilled rotors $111 ea and ceramic pads $98 set or go with something else like specialty drilled and slotted, slotted only, cryogen frozen, kevlar pads, too many choices and opinions. What has worked for you, prices and source?
Old Aug 21, 2003 | 02:14 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: C5 Front Rotors and Pads (williammease)
depends on what you are doing? Are you road racing? auto crossing? I have baer erradispeeds plus on my fronts with Z06 pads. Great stopping power.
Old Aug 21, 2003 | 02:29 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I may take some flame for this, but drilled rotors are for looks only! They crack much easier than stock.
IMHO, stock rotors (at $55 each) and pads are a great way to go unless you're doing serious track events.
To prevent warping, make sure your lug nuts are properly torqued (evenly, in stages) and try to avoid puddles/water hitting the brakes when hot.
Old Aug 21, 2003 | 02:32 PM
connellyh's Avatar
connellyh
Your rotor and pad choice are determined by your usage. Are you just street driving? Drag racing? AutoX? Road racing? Multiple usage?
I use my 99 as a daily driver and road racer. My brake set up is cryo-treated slotted rotors and hawk pads (HP+ compound, p/n: Front HB247N.575, Rear HB248N.650). This setup works faily well as a dual purpose compromise use. The HP+ have good cold stopping power and tolerate track temps well. However, they do produce a good quantity of dust. Not a good choice for a show car.
FYI, often warped rotors are mis-diagnosed. In the majority of the cases, it's pad material tranfser to the rotor surface. This gives the driver the same feedback as warped rotors because the surface is no longer uniform. You may not see the material. It may even take on a shine and look like the rotor. Since it only takes a few thousandths of an inch on material to cause pedal sensation, you probably will not feel it with your hands. A run-out test will show run-out which is the same result as a warped rotor. Generally speaking, a rotor with pad material on it is about as useful as a warped one, time to buy new ones.
Old Aug 21, 2003 | 06:02 PM
Jim 47's Avatar
Jim 47
NO
The stock rotors and pads are excellent for street use. :cool:
Jim
Old Aug 21, 2003 | 06:20 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
how many miles on those original components????/ did warping just start to occur???? Have you dramatically changed your driving habits?
Old Aug 21, 2003 | 11:14 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: C5 Front Rotors and Pads (Evil-Twin)
In 6 years of heavy use I never had a warped rotor on my 97. The stock rotors are just as good as the aftermarket high priced items.
Did somebody just do some work on your car? Just the act of removing and reinstalling the wheels can cause brake thumping if the wheels were not seated correctly on reinstallation. Lug nut torque is important but not as important as making sure the rotors are in their proper place before snugging every thing down.
Bill
Old Aug 22, 2003 | 02:16 PM
SteveNix's Avatar
SteveNix
Default Re: C5 Front Rotors and Pads (SDVette)
Where can I find front C-5 rotors for $55 each?
To C5 Front Rotors and Pads
