Missing at idle
Old Aug 21, 2003 | 03:57 PM
Blue'02's Avatar
Blue'02
Default Missing at idle
My '02 coupe seems to be missing on one cylinder at idle. The misses are intermittent, about a half second apart. Is that normal? Should I ignore it? Have the plugs checked? Thanks!
Old Aug 21, 2003 | 04:11 PM
1vette98's Avatar
1vette98
Default Re: Missing at idle (Blue'02)
My '98 was doing something similar, an occasional miss at idle and a skip on the highway between 1500 and 2000 RPM. Replaced the plugs and cleared it up. 34k miles on car. Good luck!
Old Aug 21, 2003 | 04:21 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Check the plugs and then the wires... If it still does it, use a timing light on each plug wire to see if the coils are firing correctly. This is how we found my one bad coil that eluded the dealership for 3 years. :mad
vetterdstr :cheers:
To Missing at idle
