Breaking in the Brakes
Old Aug 22, 2003 | 06:48 AM
sebrock's Avatar
sebrock
Default Breaking in the Brakes
I am installing a set of DuraStop Ceramic Pads and Drilled and Slotted Rotors (yes, I know, prone to cracking, yada, yada, yada; I just think they look cool with my red calipers). Is there a breaking in procedure? I remeber reading a thread about this, but can not find it.
Old Aug 22, 2003 | 08:12 AM
Patches's Avatar
Patches
Default Re: Breaking in the Brakes (sebrock)
http://forums.corvetteforum.com/zerothread?id=631936
:cheers:
Old Aug 22, 2003 | 10:54 AM
Kexec's Avatar
Kexec
Just installed the same set-up a few days ago. Haven't dirven the car much, but noticed some amber color residue forming on the rotors. I hope this will go away after some period. Let me know if you experience the same thing after your install. Yes they do look good and as soon as I can figure out why they look discolored and what's causing the pedal pulsing I should be satisfied with them.
:steering:
Old Aug 22, 2003 | 11:02 AM
sebrock's Avatar
sebrock
Default Re: Breaking in the Brakes (Kexec)
Did you go through the bedding procedure described in the thread above?
Old Aug 22, 2003 | 11:27 AM
Patches's Avatar
Patches
Sebrock, when I installed my Eradispeeds, I used my stock pads which only had about 2K miles on them. I was going to swap in the new Hawk pads I have and do the bedding procedure but decided not to because the stockers were so new and work well.
I would follow the procedures to a T if you want the best outcome. :yesnod:
Old Aug 22, 2003 | 03:19 PM
sebrock's Avatar
sebrock
Default Re: Breaking in the Brakes (Patches)
I've heard such bad things about all these brakes cracking - my mechanic just replaced some on a Lingenfelter that cracked his racing at Summit Point, WV - I hope I din't sacrifice racing safety and performance for looks.
Old Aug 22, 2003 | 09:22 PM
Kexec's Avatar
Kexec
Haven't had much time to dirve the car since rotors installed on Tuesday. but plan to drive it to Carlisle this weekend.
To Breaking in the Brakes
