Humidity Question
Old Aug 22, 2003 | 09:26 AM
LS7's Avatar
LS7
Default Humidity Question
Is it possible that the high humidity weve been having here on the Island could lead to pinging (tip in knock) on acceleration?
I put Chevron Techron in the car at every oil change and I run Shell premium. Seems to happen alot more when the a/c is on.
The 2000 A4 has 25,000mi. on it with stock plugs and wires. I cleaned the wires on the MAF and didn't notice any difference. They weren't even dirty. Maybe I should just go ahead and order the NGK TR55 and a set of Magnecore's. Opinions appreciated. :seeya
Old Aug 22, 2003 | 11:55 AM
carpe dm's Avatar
carpe dm
Default Re: Humidity Question (LS7)
What type of intake are you running? I'm wondering if you are "lean." Also, could part of the problem be carbon build-up? :rolleyes:
Old Aug 22, 2003 | 06:14 PM
LS7's Avatar
LS7
Default Re: Humidity Question (carpe dm)
I have the Blackwing. But , the problem was there before the new air cleaner.
Just for the heck of it, I already ordered the NGK TR55 and the MSD wires to put in. They should be here on Monday for me to install. Hope it works. :thumbs:
Old Aug 23, 2003 | 05:14 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Thats not going to solve your problem, you need to see the Vette Dr. in N.Y!
[Modified by wallstAL, 2:15 AM 8/23/2003]
Old Aug 23, 2003 | 06:22 AM
Mitch C's Avatar
Mitch C
Default Re: Humidity Question (wallstAL)
:iagree:
Give the Vettedoctors a call they will have your car running great.
[Modified by Mitch C, 5:59 AM 8/23/2003]
Old Aug 23, 2003 | 06:44 AM
LS7's Avatar
LS7
Default Re: Humidity Question (Mitch C)
Thanks for the reply's. :hurray:
To Humidity Question
