my reverse lights don't work...
Old Aug 22, 2003 | 02:54 PM
rutiger's Avatar
rutiger
Default my reverse lights don't work...
they light when i lock/unlock the car with the key fob, but they don't light when i put the car in reverse.
is there a switch that controls this function? and if so, where is it? hwo do you replace it? etc?
thanks
Old Aug 22, 2003 | 03:29 PM
FRC1999's Avatar
FRC1999
Default Re: my reverse lights don't work... (rutiger)
The same thing happened to mine. I ended up buying the switch from GMParts.com and replaced it. Its on the passenger side of the transmission forward of the drive axle. It took about twenty minutes.
Old Aug 22, 2003 | 03:31 PM
rutiger's Avatar
rutiger
Default Re: my reverse lights don't work... (FRC1999)
cool thanks. as i am still under warranty they need to pay for it but i would rather install it myself. i'll have to see how that goes.
thanks
Old Aug 22, 2003 | 03:38 PM
Phil97SVT's Avatar
Phil97SVT
The swap for the switch is very cheap and easy, jack up the rear, the switch is right on the passenger side of the tranny. Pop the old one out and install the new one, takes more time jacking the car up than it does to swap the sensor. Had the same problem in my 99.
Phillip
Old Aug 22, 2003 | 04:03 PM
rutiger's Avatar
rutiger
Default Re: my reverse lights don't work... (Phil97SVT)
i just ordered the switch. the shipping is more than the part. why does that just not seem right.
[Modified by rutiger, 1:20 PM 8/22/2003]
To my reverse lights don't work...
