Starting Problem
Old Aug 25, 2003 | 07:32 AM
AMERDRM's Avatar
AMERDRM
Default Starting Problem
I have a 99 Roadster that will occasionally not start. You turn the key and it is dead. The battery is good and after a few tries it will start.
I get the following fault codes.
B2721 Pass-Key Detectopm Circuit
P1631 Theft Deterrent System Password Incorrect-C
U1016 Loss of Communications with PCM
U1064 Loss of Communications with DCM
U1096 Loss of Communications with IPC
Can anyone help me
Old Aug 25, 2003 | 10:31 PM
luvinc5's Avatar
luvinc5
Default Re: Starting Problem (AMERDRM)
wow, that sucks
does the vette start up with the other key (without the problems)?
anyways, ttt 4 ya
Old Aug 26, 2003 | 04:29 AM
markcz's Avatar
markcz
I would put my money on one of the following:
1 - The resistor on your key is either slightly damaged or dirty/corroded to the point where it isn't reading as the proper resistance any more. Try using the other key for a while to see if the problem goes away. BTW, your car WILL NOT start for 3 minutes after you get the B2721 code, and every time you try again it just restarts the 3 minutes.
2 - Since you got all of the loss of coms codes, there might be a loose connector somewhere, probably under the steering wheel. Have you recently installed a CLB or anything else that would have had you messing with connectors anywhere inside the car?
If you figure it out, let us know what the problem was.
Good luck. :cheers:
Old Aug 26, 2003 | 10:10 AM
Fast one's Avatar
Fast one
Default Re: Starting Problem (markcz)
Another possibility is the wiring harness under the console. My '98 wouldn't start when the console was on but would start when it was removed; I retaped the wiring harness in that area and made sure the wires were off to the right of the cup holdern so the console wouldn't pinch them.
To Starting Problem
