Big Brake Kits?
Old Aug 25, 2003 | 01:53 PM
RWH's Avatar
RWH
Default Big Brake Kits?
I posted this in the Events forum by mistake, sorry. Any way, I have been considering uprgrading my brakes with larger rotors. I have been considering going with 14" rotors. I have after market wheel 18's & 19's so I think it will work. Can I use the stock calipers with the larger rotors, or do I have to change everything? I do not do much racing to speak of so it is more for appearance than anything else. Looking for suggestions/ opinions, THANKS. :skep:
Old Aug 25, 2003 | 03:45 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Big Brake Kits? (RWH)
call Lou at LGM supporting vendor
Old Aug 25, 2003 | 04:17 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I was going to do this too, but then the reality of it sunk in. The cost of these kits would represent close to 25% of the value of my 97 right now.....not good money management if you ask me. :cheers:
Old Aug 25, 2003 | 05:06 PM
Lambinator's Avatar
Lambinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In V AutoX Winner
Default Re: Big Brake Kits? ($$$frumnuttin')
Give it a month or so - Wilwood is very close to releasing their big brake kit for Vettes. This is step two to the brake upgrade they recently released.
Old Aug 25, 2003 | 06:44 PM
HIGHRPM's Avatar
HIGHRPM
Check out the Stop Tech 14" rotor, 4 piston caliper,front and rear setup. I believe this is what Farmer used to win alot of races.
Old Aug 25, 2003 | 07:08 PM
SvenOdin's Avatar
SvenOdin
Default Re: Big Brake Kits? (HIGHRPM)
They're all rather pricey. The most "cost effective" 14" rotor that will work with the stock calipers that I have found are the Baer Eradispeed +1.
In all honesty, they are really no better than stock. You just pay a hefty premium for the "bling bling".
LGM has some really nice Wilwood's coupled with DBA rotors for under $1700 (front AND rear) if I'm not mistaken.
Old Aug 25, 2003 | 07:44 PM
YELLOHHH's Avatar
YELLOHHH
If you're gonna do it, do it right. Brembo. Pictures at website below.
Old Aug 25, 2003 | 09:36 PM
$$$frumnuttin'
Default Re: Big Brake Kits? (SvenOdin)
Amen, Svenodin. I'm getting over the drilled look real fast. I can paint the rusty portion of the stock rotor for cheap and still get some bling-bling. :cheers: When you think about it , it's just the freakin' brakes. I'd much rather put that kind of cash into a supercharger or ?? the C5 stops pretty damn good right out of the box IMHO. :cheers:
Old Aug 26, 2003 | 12:06 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I dont know of any 14" rotors that look good and are low cost. If you want great looking rotors at a low cost, buy the zinc plated, cross drilled and slotted baers. :cheers:
VR :cheers:
Old Aug 26, 2003 | 12:35 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi,
Our web site is not always up to date, so see below.
You can use the Wilwood 2 peice front rotors with our Wilwood 6 piston caliper set up for only 1699 for the front, or $1949 for the kit including the matching 1 piece rear rotors.
The kit includes the Wilwood 2 piece front rotors, 6 piston calipers, SS brake lines, Poly matrix brake pads and all the hardware to complete the installation. Plus the rear matching rotors for an additional $250 when purchased with the fronts.
Or you can get the set up like the bottom photo, and use the 1 peice DBA rotors, in either drilled and slotted, or just slotted. Fronts only=$1499, for the kit including the front 6 piston calipers also. Add $200 to include matching rear DBA rotors.
If you are confused, just give me a call at LG Motorsports 972-272-7753.
Lou G
These are the Wilwood front rotors that can be used with our Wilwood 6 piston calipers below
below is the wilwood matching 1 piece rear rotor
Below is the LG Motorsports Front brake package with Wilwood 6 piston calipers and DBA rotors.
Old Aug 26, 2003 | 12:39 AM
LG Motorsports
Default Re: Big Brake Kits? (LG Motorsports)
Or we have the full Wilwood package just released for the front and rear for $3399 for the front and rear kits combined, as the photo shows complete with SS brake lines. Available at LG Motorsports
LG
Front and rear package now #3399.00 complete
[Modified by LG Motorsports, 11:40 PM 8/25/2003]
[Modified by LG Motorsports, 12:24 AM 8/28/2003]
Old Aug 26, 2003 | 10:49 PM
C5-VERT's Avatar
C5-VERT
Going with BIG BRAKES was the most dramatic mod I have done. Even more impressive than the 700+ hp I have. Running 275mm tires up front it really puts you through the windshield. There is NO comparison of the stock brakes against my aftermarket setup.
Not quite finished painting...
Proportioning valve...
[Modified by C5-VERT, 10:51 PM 8/26/2003]
Old Aug 27, 2003 | 01:58 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
RWH,
Check this thread out:
http://forums.corvetteforum.com/zero...=620731&page=2
The Wilwood 6 Piston Front/4 Piston Rear Brake System GP is a GO!!!
Read my last post on this thread for complete details.
Thanks!
Shawn
Old Aug 28, 2003 | 01:21 AM
LG Motorsports
New sale pricing no minimum orders required and Stainless steel brake lines included for $3399 for the complete front and rear package from Wilwood. I have been an OEM WD for Wilwood since 1995 and I do not have to "buy in" with Wilwood, So I can offer this special pricing with NO MINUMUM orders.
I will ship as each order is taken, and will ship the same day. This package is different than my own package in that the rotor has more offset to fit the stock wheels. It is slightly more expensive than my LGM G stop package but I am more than willing to give this offer to the Corvette Community for a limited time.
You can place your immediate order at LGMotorsports at 972-272-7753
Lou G
NEW PRICING $3399. COMPLETE WITH SS BRAKE LINES
[Modified by LG Motorsports, 12:22 AM 8/28/2003]
To Big Brake Kits?
