Delco AGM
Old Aug 25, 2003 | 04:29 PM
Fast98's Avatar
Fast98
Default Delco AGM
Will a battery out of a 2002 work in a 98,and if not what is the part # for a delco agm battery for a 98 thanks
Old Aug 25, 2003 | 04:45 PM
Jim D's Avatar
Jim D
Default Re: Delco AGM (Fast98)
I used one from an 02, its a little smaller then the battery you have in your 98. I just cut the foam protector and reglued, no problem,good luck Jim.
Old Aug 25, 2003 | 04:59 PM
Fast98's Avatar
Fast98
Default Re: Delco AGM (Jim D)
Thanks the parts guy told me it would fit,and they are hard to get right now for some reason,I just want to get my old acid one out of there it has been there long enough.
Old Aug 25, 2003 | 06:30 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
i put the new AGM battery in my 98.
78P7YR
part# 19002255.
that was my thinking. my original battery was fine, but i didn't want to press my luck.
To Delco AGM
