Cryogenic Air Intake
Old Aug 25, 2003 | 10:47 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Cryogenic Air Intake
I'm looking at installing a cryogenic air intake system from Design Engineering on my car. Does anyone have any experience with this type of product?
Old Aug 25, 2003 | 11:38 PM
KF9BD's Avatar
KF9BD
Default Re: Cryogenic Air Intake (JerryL)
Cyrogenic,,,,,like in liquid nitrogen???? That would certainly provide cold air. I would be concerned about the effects from the extreme cold on the intake parts.......... :D :D :D :D
Old Aug 26, 2003 | 12:14 AM
Cybercop's Avatar
Cybercop
Default Re: Cryogenic Air Intake (KF9BD)
Can I pipe that through my intercoolers? :p:
Old Aug 26, 2003 | 09:04 AM
T2001W's Avatar
T2001W
Default Re: Cryogenic Air Intake (Mike00FRC)
Just ccheck it out!!
designengineering.com
Old Aug 26, 2003 | 09:34 AM
The Batman's Avatar
The Batman
Looks like you can spray it on your intercoolers. That seems like a workable idea, but cooling the air intake? Isnt that kind of like putting an ice pack around the nozzle of a garden hose? Does the water coming out of the hose instantly get cold? I dunno, haven't tried it, but my thought experiment hypothesis leans toward no. Also a big V8 engine is moving a lot of air. Is that air in the intake long enough to cool? The cooling chamber for this system doesn't look very effective, but who knows?
Old Aug 26, 2003 | 10:27 AM
kromberg's Avatar
kromberg
Default Re: Cryogenic Air Intake (The Batman)
I have seen a lot of ricers use setups like this. I think it woul dbe somwhat effective at coolin gthe intake temp of 1.7L motor. Any motor larger would not see anything.
Keith
Old Aug 26, 2003 | 11:34 AM
pburant's Avatar
pburant
Default Re: Cryogenic Air Intake (kromberg)
Interesting idea, but not very much info on the website.
I would wonder whether they have a model that will flow enough for an LS1. It sounds like they force the intake air into a tube that contains the special bulb - if this tube/bulb does not flow enough CFM, any thermal benefits would be wiped out.
Also, because it's CO2 powered, it works much like nitrous - you only cool at WOT. If you're gonna do this, you might as well install a nitrous system - probably costs the same and gives far more power.
-Pete
Old Aug 26, 2003 | 11:40 AM
bhamvett's Avatar
bhamvett
Default Re: Cryogenic Air Intake (pburant)
I would like to see a dyno chart first.
Old Aug 26, 2003 | 12:00 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
A local tuner I no said they installed one of these systems on a car and it made no hp gain. He also said it was a pain in the butt to put on a vette.His company was working on a system that would cool better and make more hp. It should be out late this year. :thumbs:
To Cryogenic Air Intake
