C5's With Stereo Systems need help
Old Aug 27, 2003 | 01:43 PM
C5lyin's Avatar
C5lyin
Default C5's With Stereo Systems need help
I am trying to figure out the best way to install a 10" sub and amp in the middle storage space using the cover as a type of speaker box, perminatley fixed to the car ofcourse. My question is can i run my fosgate amp of of either A.) the Amp that is in the driverside space or B.) the CD Changer..which has been cleverly relocated. If i can run the power/wiring off of either the 2 of these which do i run off of. i guess i am being lazy and i could run a meter on all the wires but heck if someone has done it why not learn from wisdom. Any help is appreciated.. Also any suggestions.
Ethan
Old Aug 27, 2003 | 03:05 PM
leolufse's Avatar
leolufse
Default Re: C5's With Stereo Systems need help (C5lyin)
Post this in the Audio section of this forum.
Old Aug 27, 2003 | 07:14 PM
KorbenDallas's Avatar
KorbenDallas
Maybe this will help: http://forums.corvetteforum.com/zerothread?id=560046
I have since added a Kicker G12 aluminum speaker grill to protect the sub.
Old Aug 28, 2003 | 09:15 AM
C5JONNY's Avatar
C5JONNY
Get a custom job and be done with it.
Old Aug 28, 2003 | 09:39 AM
markcz's Avatar
markcz
All of your wiring questions can probably be answered here.
https://www.corvetteforum.com/techti...=120&TopicID=1
:cheers:
Old Aug 28, 2003 | 09:51 AM
Closer_2001's Avatar
Closer_2001
This will probably get moved...but here we go.
First - You will want to make some type of enclosure for the sub. JL Audio makes a Stealth Box with an integrated cover that looks stock. A forum member makes one as well. I made one myself out of fiberglass and used the stock cover with hidden holes beneath the factory carpet to let the woofer vent.
If you make one, you may be able to make a large enough box that incorporates enough space for your amp. I have even seen a design where the amp was mounted below the box in teh bottom of the compartment and had fan cooling.
The vertical space between the Targa securing rods also makes a good spot to mount an amp.
Regardless - You will need to run dedicated power leads straight to the battery to power the amp. You can tap into the head unit for pre-amp signal for the sub amp. Search for 99HT He has documented the steps very nicely.
I would not recommend using the compartment cover as some type of baffle, as the box will not seal well and your bass will be weak.
Old Aug 28, 2003 | 11:00 AM
BadazzC5's Avatar
BadazzC5
St. Jude Contributor
Default Re: C5's With Stereo Systems need help (C5JONNY)
Nice amp...Jonny :thumbs:
Old Aug 28, 2003 | 01:33 PM
C5JONNY's Avatar
C5JONNY
Default Re: C5's With Stereo Systems need help (BadazzC5)
Thanks the whole setup sounds awesome. Makes my C5 expirience that more enjoyable.
To C5's With Stereo Systems need help
