Finally removed blown differential... serious carnage
Old Aug 28, 2003 | 03:51 PM
rwj383's Avatar
rwj383
Default Finally removed blown differential... serious carnage
Here you go. The pics dont do the damage to the case any justice. The diff case is shattered and cracked in many places. Anyway, I'm a tad confused what is broke here. It looks to me as if the pinion gear shaft is broke, not the trans output shaft?? the shaft broke within the differential itself, so, I would consider that being the pinion shaft. ??
i'm waiting for Rodney to call me back. I hope this is not the trans output shaft. BTW, I did get the diff out without dropping the torq tube and trans. I tilted the drivetrain to the suggested angle limit, then I took the diff off at the 5 bolts. damn, the diff is crazy busted.
Robert
Old Aug 28, 2003 | 04:01 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Finally removed blown differential... serious carnage (rwj383)
Robert,
<cringe> That is the transmission output shaft. Your going to need to repair that with either a new tranny or replace that shaft with a 300m one from Lingenfelter. 9 times out of 10 the output shaft for the differential are the one's that sheer off. I think the LPE shaft is 4-600 beans.
Phillip
Old Aug 28, 2003 | 04:05 PM
90 droptop's Avatar
90 droptop
SHAZAM!!
Old Aug 28, 2003 | 04:07 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Finally removed blown differential... serious carnage (90 droptop)
ouch.......... :eek: good luck with the repairs.......... :yesnod:
[Modified by MC TORCH RED, 3:07 PM 8/28/2003]
Old Aug 28, 2003 | 04:11 PM
dahoof's Avatar
dahoof
Default Re: Finally removed blown differential... serious carnage (MC TORCH RED)
That is narly! Let us know how you come out! :cheers:
Old Aug 28, 2003 | 04:20 PM
The One's Avatar
The One
That just looks way too familiar. :(
Good luck getting the LPE mainshaft - they never have one in stock. :rant:
At the least the back half of your tranny is still there. Mine was not. :eek:
Good luck with the rebuild. I'm sure it will be better/stronger than ever! :cheers:
Old Aug 28, 2003 | 04:58 PM
BayouVette's Avatar
BayouVette
Default Re: Finally removed blown differential... serious carnage (The One)
Thats some serious breakage. That thing is all broke up :eek:
Old Aug 28, 2003 | 05:17 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Finally removed blown differential... serious carnage (Phil97SVT)
Robert,
Phillip
:iagree:
Those last couple of pics are of the broken output shaft :sad:
Old Aug 28, 2003 | 06:08 PM
larrysb's Avatar
larrysb
Default Re: Finally removed blown differential... serious carnage (runamuk)
Whoa. that's some serious breakage there. Looks kinda expensive.
Old Aug 28, 2003 | 07:48 PM
mdhmi's Avatar
mdhmi
Default Re: Finally removed blown differential... serious carnage (larrysb)
What were you doing when the bomb detonated ?
Mark
Old Aug 28, 2003 | 07:53 PM
REDKOOP's Avatar
REDKOOP
Default Re: Finally removed blown differential... serious carnage (mdhmi@yahoo.com)
Someone on the forum has a complete transaxle setup brand new tor about $2500.00 I think. Might be your best bet. It's still in the crate too.
George
Old Aug 28, 2003 | 09:11 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Robert,
That looks a lot like the one in this pic I saved from a post a while back...it's not mine.
I want more info on the case on the right.
Looks a lot stronger to me.
Old Aug 28, 2003 | 09:14 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Ouch, ouch :eek:
Talk to John at 21st Century (972 417 7177). Might have a fix for you.
:cheers:
Old Aug 28, 2003 | 09:29 PM
luvinc5's Avatar
luvinc5
Mark
I wanna know also.
Old Aug 28, 2003 | 10:33 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Finally removed blown differential... serious carnage (luvinc5)
:lurk:
Old Aug 28, 2003 | 10:59 PM
z0sense's Avatar
z0sense
Default Re: Finally removed blown differential... serious carnage (SHOWTIME!)
I had the same problem. The shaft is about 300 from GM and the install runs about 250.00 with the tranny out of the car....only about 20 minutes away with the differential out:)
BTW,
I have just a case if you need it....also you may want to take off the rear cover of the differential I am almost positive that it broke the pinion carrier also. If this is the case you will have to buy a new rear differential......
I have now seen 4 people have this exact same problem (including myself) and have yet to see a recent differential output shaft break!!!!!!!!!
Old Aug 29, 2003 | 06:04 AM
larrysb's Avatar
larrysb
Mark
I dunno, but it sure looks like he was doing it right!
Sorry for the carnage, but hey, my hat's off to yah.
:cheers: :cheers: :cheers:
To Finally removed blown differential... serious carnage
Old Aug 29, 2003 | 08:04 AM
rwj383's Avatar
rwj383
I was racing a new BMW M3 coupe. I was doing about 75mph when i armed BOTH stages of the nitrous, then shifted to 3rd, popped clutch and punched it at same time when-- BANG!!!....the fruggin rear end let loose. fluid everywhere, on my exhaust, I was smoking and everything. It was really pretty cool!!!! I was already VERY far ahead of the beemer by that time, so, it was a successful kill.
I talked to Shirl Dickey of SDRE, who builds my motors for me and he suggests i may be able to replace my own trans output shaft. Maybe even while trans still in the car???? He's not so sure about that, but, I would LOVE to be able to do it while the trans is still in. Anyone?? BTW, I blame Shirl directly for the extent of this damage. His motor broke my car!!! Way too much power for the stock drivetrain....
Robert
The diff is obviously beyond repair. Rodney did call me back last night while i was asleep, so, I wll call him today to get squared away on needed parts.
Flyin-Brian- the case on left you picture is an 'A' case that housed the lower A4 gears (2.74) the case on the right is a 'B' case and houses the higher gears. I believe this is right....
[Modified by rwj383, 5:08 AM 8/29/2003]
Old Aug 29, 2003 | 08:09 AM
rwj383's Avatar
rwj383
Default Re: Finally removed blown differential... serious carnage (REDKOOP)
who??
Old Aug 29, 2003 | 08:19 AM
Flyin'Brian
Cruise-In I Veteran
If that IS the difference between the 2 series and 3 series cases, then you should switch to the case like the one on the right in that pic.
From your pic it looks like you had the weaker case, is that true?
