Isky springs for LS1
Old Aug 30, 2003 | 07:44 PM
blktie8's Avatar
blktie8
Default Isky springs for LS1
Wonder if any of the tuners are using The Isky 13800 springs
They are much more expensive,are they worth it
Anybody
Old Aug 30, 2003 | 08:07 PM
kumar75150's Avatar
kumar75150
Default Re: Isky springs for LS1 (blktie8)
My tuner uses the Isky 295D springs. I am not sure about the ones you mentioned. Are they Isky's double springs.
BTW, the Isky 295D will handle a lot of lift and I have never seen a spring break. I am running a .630 lift cam on mine with absolutely zero problems.
Old Aug 30, 2003 | 09:31 PM
X_03_Cobra_guy's Avatar
X_03_Cobra_guy
Default Re: Isky springs for LS1 (kumar75150)
Where did you get your Isky springs. I want some for my Z06 Heads I am putting on my car.
Old Aug 30, 2003 | 11:48 PM
blktie8's Avatar
blktie8
Thanks for the info.
I want the best springs without loosing HP because of the weight of the springs
[Modified by blktie8, 11:49 PM 8/30/2003]
Old Aug 31, 2003 | 01:52 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I am also using the 235D that I got from MTI!
Old Aug 31, 2003 | 05:07 AM
kumar75150's Avatar
kumar75150
Default Re: Isky springs for LS1 (X_03_Cobra_guy)
I got it from MMT (board sponsor on the left). They use them on every single one of their heads/cam packages.
To Isky springs for LS1
