I think I am gonna go w/ a dual friction from centerforce. Anyone use this clutch? I can get new ones for around $350.00. Does anyone have an idea what instal would cost? Thanks, kaley
I believe 400 or 600.00, for install,I'm home and I forget.Drive to AZ. we'll throw some 3:73's in there for a few bucks more,Dave Smilovic
dave@xtrememotorsports.com/480-517-4969
I paid $450 for an install at a local tuner here in the Dallas area.
Run don't walk away from the CF (stands for Cluster F&*^) clutch. They suck. There are many other alternatives. If you are basically stock with only bolt ons then upgrade to a Z06 clutch, pressure plate, slave and master cylinder. If you have H/C or nitrous then look at the Ram set up.
Whatever you do do not put a CF clutch in the C5. You may get lucky bust most likely you will be sorry.
Dave, The drive to AZ is a bit much for a clutch instal. I would rather have 4:10's. I will drive down there if you do the clutch/gears/instal for $1200.00. How does that sound? :D
