SPEC stg 3 Break in?
Old Sep 3, 2003 | 09:30 AM
Mike TexaSS's Avatar
Mike TexaSS
Default SPEC stg 3 Break in?
Last night i picked up my car with the following mods.
382 LS1 Lunati Stroker Kit
Stage 2 heads w 2.02 1.60 valves
MTI X1 Cam
LS6 Intake
Katech Throttle Body
ASP underdrive Pulley
I added a SPEC Stage 3 clutch with Steel Flywheel. The car only has about 125 miles on this combo. The clutch if not properly slipped will shake the whole car. I basicly have to do a fairly aggresive launch to get no chatter.
Will this end once i get more miles on the clutch? How are others SPEC stg 3 clutches working?
Opinions and comments wanted!
:grouphug:
Old Sep 3, 2003 | 09:32 AM
'97 C5's Avatar
'97 C5
Default Re: SPEC stg 3 Break in? (Mike TexaSS)
It will take more miles (500) but yes, it will eventually launch nearly as smooth as a factory unit.
Old Sep 3, 2003 | 09:40 AM
Mike TexaSS
Default Re: SPEC stg 3 Break in? ('97 C5)
Awsome that what i was looking for.
I do have completely stock 99 Hydraulics slave master ect? Would upgrading to Z06 parts help much?
Old Sep 3, 2003 | 03:00 PM
Mike TexaSS
TTT :crazy:
Old Sep 3, 2003 | 03:47 PM
dahoof's Avatar
dahoof
I have a spec 3 stage with a z06 slave. It would be in the best interest to upgrade to z06 components. It took about a 1000 miles to fully break in. No issues now and it holds great. :cheers:
Old Sep 3, 2003 | 04:25 PM
HIGHRPM's Avatar
HIGHRPM
I have about 600 miles on my Spec III...its getting smoother....still needs a little more town driving. It was pretty rough the first few hundred miles. Now, most of the time I can't tell any difference from the stock clutch. It holds the 677/688 without slipping. :cheers:
Old Sep 3, 2003 | 04:30 PM
DRK-SYD's Avatar
DRK-SYD
Mike you old dog..you were supposed to wait until I got mine..congrats on the combo :cheers: What kinda power is she making, if you don't mind me asking :D
Old Sep 3, 2003 | 04:35 PM
Mike TexaSS
Default Re: SPEC stg 3 Break in? (DRK-SYD)
I go in for a dyno tune on fri. I expect at least 440 RWHP and At least 420 RWTQ.
We shall see. But it feels way faster than the impy!
Old Sep 3, 2003 | 04:50 PM
DRK-SYD's Avatar
DRK-SYD
You should hit those #'s with no problem..I'd expect a little higher even. Let me know :yesnod:
Old Sep 3, 2003 | 04:51 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
All '02 hydraulics are the same, including Z06.
I have about 7k miles on my SPEC III w/ Fidanza aluminum flywheel. Every now and then if I do alot of stop and go driving it will still chatter some. A steel flywheel may help you more. Good clutch. Held over 700hp with 4-5k clutch dumps w/ a CCW drag package.
To SPEC stg 3 Break in?
