LGM pro long tubes......dipstick question...
Old Sep 3, 2003 | 11:36 AM
Phil97SVT's Avatar
Phil97SVT
Default LGM pro long tubes......dipstick question...
My dipstick doesnt seem to fit all of the way into the block. If I unbolt the hanger on the header it will push in another 1/4" and lock into place but the bolt hole is now 1/4" to low? Should I just drill a new hole?
Phillip
Old Sep 3, 2003 | 11:43 AM
corvette184's Avatar
corvette184
Default Re: LGM pro long tubes......dipstick question... (Phil97SVT)
i would bend the tab so it fits correctly........i just installed stainless works headers and i had to grind and reshape the tab on the the dipstick tube to fit correctly....it may have got bent some during your install :cheers: :cheers:
Old Sep 3, 2003 | 11:58 AM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Same problem here. I just pulled out the hand grinder and worked off enough of the tab to seat.
Old Sep 3, 2003 | 01:30 PM
schpodie's Avatar
schpodie
we had a hell of a time getting mine in too. It eventually lined up perfectly...no bending and no cutting. I will see if I have a pic with orientation shown. If not I can snap one this evening after work.
To LGM pro long tubes......dipstick question...
