Spark Plug recommendations
Old Sep 3, 2003 | 07:29 PM
lachancs's Avatar
lachancs
Default Spark Plug recommendations
I'm thinking about replacing the stock plugs in my vette and wanted to hear recommendations from others who have done this. I've read a lot of good things about Bosch plugs and NGK 55 plugs. Opinions please. . . :flag
Old Sep 3, 2003 | 07:37 PM
Scubanme's Avatar
Scubanme
Default Re: Spark Plug recommendations (lachancs)
I am using NGK TR-55 IX, they seem to be doing really well.
:cheers:
Old Sep 3, 2003 | 07:45 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Spark Plug recommendations (Scubanme)
Do plugs really make a difference? :confused:
Old Sep 3, 2003 | 07:48 PM
jmX's Avatar
jmX
Default Re: Spark Plug recommendations (lager99)
NGK TR55's are what just about everybody uses, and they work well. TR6's would be for nitrous applications or to try to reduce detonation if it is an issue on your car.
Old Sep 3, 2003 | 08:09 PM
lachancs's Avatar
lachancs
Default Re: Spark Plug recommendations (jmX)
What about the Bosch +4 plugs? They look pretty cool anyway. .???
Old Sep 4, 2003 | 10:20 AM
NassauBlue's Avatar
NassauBlue
Anyone else using the replacement plug currently reccommended by AC-Delco? It is plug number 41-985, which is an Iridium plug. The original plug was 41-931, which is platinum. So far, I've noticed a smoother idle. The plugs extend further into the combution chamber that the originals.
Old Sep 4, 2003 | 10:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I put a set of Bosch +4s in my 2001 Coupe a year and half ago, when the "loose puck" frenzy was going on. Car's been running just fine since then......
Old Sep 4, 2003 | 10:48 AM
sebrock's Avatar
sebrock
Default Re: Spark Plug recommendations (leadfoot4)
I use Silverstone plugs; they work pretty well but I'm sure they are not worht the money.
To Spark Plug recommendations
