K&N filter for VR-1B?
Old Sep 4, 2003 | 09:38 AM
Tombone's Avatar
Tombone
Default K&N filter for VR-1B?
Don't like the construction of the filter supplied for my Vararam VR-1B system.
Do you know which size K&N filter will fitl
Thanks, Tom. :confused:
Old Sep 4, 2003 | 11:39 PM
X_03_Cobra_guy's Avatar
X_03_Cobra_guy
Default Re: K&N filter for VR-1B? (Tombone)
I am interested in this too
Old Sep 5, 2003 | 03:20 PM
TNTC5's Avatar
TNTC5
Vararam K&N filter part# 33-2522
Old Sep 5, 2003 | 04:47 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: K&N filter for VR-1B? (TNTC5)
Which crosses to a AC# A1337c
Old Sep 5, 2003 | 06:24 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: K&N filter for VR-1B? (Flyin'Brian)
Is the AC# a paper filter? Unoiled? I had the K&N but when I checked it the last time I had oil streaks all over inside the air scoop and the TB was also very oily. I am concerned that they are over oiled and will gum up my MAF sensor and then the car will run like poopie. Anyone else experience this???
[Modified by Z06ufgrad2002, 6:25 PM 9/5/2003]
Old Sep 8, 2003 | 01:05 PM
H82BFST's Avatar
H82BFST
What are the dimensions of the K&N filter (no measuring the rubber seal)?
Just asking because a 346ci V8 reving to 6600rpm needs at least 110 square inches of minimum filter size.
346ci V8 reving to 7000rpm needs ~117 square inches.
To give you an idea here are a few:
ZR1 filter - 10x17 - 170si (enough for a 436cid past 8K)
LS1 Fbody - 14.5x6.5 - 94.25 (enough for the STOCK LS1 to 5700rpm)
C5 vette - ???
I'm just wondering because the above K&N filter crosses references as a 1974-1982 Triump TR-7 replacement filter and I'm a little concerned about size?
Old Sep 8, 2003 | 01:47 PM
H82BFST's Avatar
H82BFST
Filters (K&N)
33-2522 - 17.125"(L)x8.25"(W)x1.75"(H) - 141.29square inches - 3 (seals) = 138.28 VaraRam replacement stated above
33-2111 - 17.125"(L)x8.25"(W)x1.75"(H) - 141.29square inches - 3 (seals) = 138.28 Corvette C5
33-2118 - 17.125"(L)x8.25"(W)x1.75"(H) - 141.29square inches - 3 (seals) = 138.28 LS1 Fbody
33-2035 - 12.125"(L)x18.25(W)x1.75"(H) - 221.28square inches - 3 (seals) = 218.28 LT1 Corvette
These are K&N dimensions... hmmm... will have to measure some myself...
Old Sep 8, 2003 | 04:25 PM
jjcslynn's Avatar
jjcslynn
Where can I get one and how much are they?
Old Sep 8, 2003 | 06:49 PM
Z06ufgrad2002
Default Re: K&N filter for VR-1B? (H82BFST)
Filters (K&N)
33-2522 Actual filtter area measursements are 14 1/2 x 4 3/8 x ~5/8.
Old Sep 8, 2003 | 09:06 PM
H82BFST's Avatar
H82BFST
Default Re: K&N filter for VR-1B? (Z06ufgrad2002)
That's weird, my K&N database from 9/4/03 shows it as 17.125"x1.75"
Did you measure the actual inside area?
Old Sep 9, 2003 | 02:06 PM
Z06ufgrad2002
Yes, those numbers are the actual "filter area". Not the rubber surround.
That datebase is wrong. If the filter was only 1.75" wide it would fall into hole and I can assure you it is not 1.75" thick.
Old Sep 9, 2003 | 02:28 PM
H82BFST's Avatar
H82BFST
Sorry, meant to say:
Old Sep 9, 2003 | 05:15 PM
Flyin'Brian
Cruise-In I Veteran
Here is where I've been looking for info http://www.pajero.dn.ru/kn/
[Modified by Flyin'Brian, 8:17 AM 9/10/2003]
Old Sep 12, 2003 | 10:47 PM
C7GrandSport's Avatar
C7GrandSport
According to Vararam, they have to modify the K&N to fit their unit properly. This is what I had them do. I am now much more confident then when I had that flimsy piece of foam known as the "race filter" falling apart.
To K&N filter for VR-1B?
