Anyone using the TRAP intake?
Old Sep 4, 2003 | 11:30 PM
dave777's Avatar
dave777
St. Jude Contributor
Default Anyone using the TRAP intake?
I have just bought a TRAP intake system. Before I install it, I am just curious if I should do anything else to get the full effect from it. I have an 02 coupe, I have installed the Z06 screens, but I still have the factory "close-out" boxes behind them so there is no airflow advantage. Do I need to do anything different to this or just install the TRAP and go?
Old Sep 5, 2003 | 12:02 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Re: Anyone using the TRAP intake? (dave777)
ya throw the stock things out and go from there. good luck
Old Sep 5, 2003 | 01:44 PM
2000TicketMachine's Avatar
2000TicketMachine
Default Re: Anyone using the TRAP intake? (stunna)
I installed the TRAP a couple of months ago. I would either remove the foglight shrouds or drill a few large holes in them. Also, when you're installing it, don't skip the step that tells you to cut about an inch off of the styrofoam on the bumber where the TRAP will rest against it. You DO need that clearance. I didn't do it because it was too hard to get to to cut. As a result I had to really stretch the front fascia to get it back in place and it's still not totally even. Let me know if you have any other questions. :cheers:
Old Sep 5, 2003 | 11:15 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: Anyone using the TRAP intake? (2000TicketMachine)
Quote-
Did you have the 6" filter or 6.5"?
I had trouble with my lower valance too. It was said that the smaller filter should not require trimming the foam.
I would like to know if there is a difference.
Thanks!!
Old Sep 5, 2003 | 11:39 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Do you have a link to this? I have the installation cd, downloaded the one from the website and read the instructions on the site..... :confused: :cheers:
[Modified by Mean Blue Z02, 11:40 PM 9/5/2003]
Old Sep 5, 2003 | 11:49 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: Anyone using the TRAP intake? (Mean Blue Z02)
Mean Blue Z02
I could not download the install .
Had to wing it!!!!!!!!!!
I'll take a look at the foam tomorrow.
THANKS
Old Sep 6, 2003 | 08:33 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Anyone using the TRAP intake? (ALLKAR)
Mean Blue Z02
THANKS
:cool:...thanks man, I'd appreciate anything you can offer, pics....advice.... anything, :cheers:
Old Sep 6, 2003 | 12:20 PM
FreddyG's Avatar
FreddyG
I got the big filter, and didn't have to do this step. mine fit in there great. I just took my time, and fit everything in there loosely, until I got it just right, and then tightened it up.
Old Sep 6, 2003 | 04:29 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Anyone using the TRAP intake? (LuvmyC5)
Do you have the carbon one or the "standard" version?
Old Sep 7, 2003 | 10:57 PM
ndirishr1's Avatar
ndirishr1
What is this and where can I find some info on it? Thanks
Old Sep 8, 2003 | 12:49 AM
dave777's Avatar
dave777
Default Re: Anyone using the TRAP intake? (ndirishr1)
http://www.corvettec5.com/
Old Sep 8, 2003 | 02:19 AM
Allthatpunk's Avatar
Allthatpunk
Bill has recently I'm almost sure got some anazing#'s with a few before and after Trap systems amd I believe we may have stored the data.I want to quote a # but with that and an FLP type exhaust with stainless works header.Stinger cat back and the Trap on the car,well I wont quote by memory.480-517-4969,or contact us on our link under XtremeMotorSports,Dave Smilovic
Old Sep 8, 2003 | 02:36 PM
2000TicketMachine
Default Re: Anyone using the TRAP intake? (Allthatpunk)
ALLKAR: I'm not sure what size filter I have. When I bought it I was unaware that there was more than one. Unless they changed it, I don't see how you could fit it under the bumber without some cutting though.
Mean Blue: I just downloaded the instructions from Halltech's web site.
I'd be happy to offer advice to someone installing this system. It was a bit of a knuckle buster, but I do like the system.
Old Sep 8, 2003 | 03:47 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
:)....I have that and the cd, just didn't see anything about cutting/trimming the foam...any info on that would be greatly appreciated :) :cheers:
Old Sep 8, 2003 | 04:03 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
The original instructions indicated some trimming of the foam. That is no longer necessary with a newly designed Warhead filter.
Jim Hall
To Anyone using the TRAP intake?
