Strange noise from abs unit..... Help
Old Sep 5, 2003 | 03:00 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Strange noise from abs unit..... Help
I thought I had a wheel bearing going out but we finally got the car on a lift today. When you get up tp about 20 mph with the wheels in the air the abs module at the rear axle sounds like it is running. This is the hum I've been hearing inside the car. The computer is throwing no codes and after listening closely it appears that the abs module starts to hum as soon as you start the car. The warning light is working but goes out as normal after about 3 seconds.
Anybody have any ideas/suggestions? It's on a 98 MN6.
