Please help me diagnose
Old Sep 5, 2003 | 04:04 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Please help me diagnose
I had shocks, sways and tires installed at the same time...
Now around 70 MPH the car begins to vibrate. Over 90 and it feels like it will shake apart. The steering wheel is shaking as is the entire car..
I check and I have all of my weights on the rims... Is this a symptom of the wheels out of balance?
Old Sep 5, 2003 | 04:12 PM
gonbad's Avatar
gonbad
Default Re: Please help me diagnose (ICULUKN-C5)
First, jack up the car and make sure the swaybar brackets and end links are tight. Check the shocks mounting points as well.
Most likely you have spun a weight out of its original position or it was not balanced correctly in the first place. Having a weight move on the wheel is not uncommon.
Other possible culprit is a bad tire where the belts are not overlapping each other properly.
Old Sep 5, 2003 | 04:28 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You need to take it back to whoever did the work, if you start messing with the car they'll try to blame you for the vibration.
More than likely it's a wheel out of balance, just because the weights are on the wheels doesn't mean that they're in the right place. :cheers:
Old Sep 5, 2003 | 04:36 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Sounds like a wheel weight to me... If a lazy tech cant get the wheel balanced he will just let it go... figuring you wont know the difference... I wont have my wheels balanced anywhere unless I can watch.. see the out of balance condition. See them add the weight and recheck the balance.. If I dont see 00 00 . I wont accept the balance... Some times rotating the tire 90 degrees on the rim will help with a severely unbalanced wheel.
Also in your case a recheck of the sways and shock mounts etc. I would demand to see the tires rebalanced and their actual condition of balance before they correct anything.. those tires should all see 00 00 on the balancer..
Old Sep 5, 2003 | 06:18 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Please help me diagnose (Evil-Twin)
Tires are brand new.... Going back to the shop tomorrow..
Old Sep 6, 2003 | 02:14 PM
carpe dm's Avatar
carpe dm
Sounds like it to me. Have them do a "dynamic" balance if possible. Good luck. :smash:
Old Sep 6, 2003 | 04:35 PM
WWK888's Avatar
WWK888
Default Re: Please help me diagnose (carpe dm)
Try find a shop that uses the Hunter balancing machine...its the best out there IMHO. :cheers:
Old Sep 7, 2003 | 09:12 AM
JaminJ's Avatar
JaminJ
Glen, If you continue to have problems and can't resolve. Try Network Alignment...go to the one @ 67th Ave + Bethany Home Rd. I think the guys name is Brennan..he only works on the lift next to waiting area. Knows his s_it. Tell him how you drive your car and he can mod from heavy auto cross to total street. He does alot of the Corvette autocrossers alignments.
He will find the problem..
Good luck
John :cheers:
[Modified by 2000 Pewter Hardtop, 9:13 AM 9/7/2003]
To Please help me diagnose
