Hurst is in!!!
Old Sep 6, 2003 | 08:31 PM
USARMYTTT's Avatar
USARMYTTT
Default Hurst is in!!!
I LIKE IT!!!!! It took about 1.5 hours to install, absolutely no problems thanks to the tech tips from Patches. On the test drive I did not notice any unusual sounds. I did find that my boot ring is broke in two places(probably done by the stereo installer). I will be ordering a Ken King short boot soon. If you are considering one of these, I say go for it! I even took a picture so I didn't get the ole :bs flag.
Old Sep 6, 2003 | 09:46 PM
SSTRUCKNGUY's Avatar
SSTRUCKNGUY
Default Re: Hurst is in!!! (USARMYTTT)
i take it this is a short throw shifter???? how much of a diffrence is there if it is??
Old Sep 7, 2003 | 12:37 AM
88sk's Avatar
88sk
Default Re: Hurst is in!!! (SSTRUCKNGUY)
first mod I did I love it, the stock one is sloppy compared to the hurst,short ,prcise shifting compared to stock,I got the mgw gripper **** & you feeel much more in touch with the shifter compared to the stock leather ****,hurst is IMO the best because of adjustability& price.
Old Sep 7, 2003 | 03:59 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Hurst is in!!! (88sk)
Yep, Hurst is the way to go...and the adjustable springs help a lot. :cheers:
Old Sep 7, 2003 | 04:48 AM
jmzvet's Avatar
jmzvet
Default Re: Hurst is in!!! (FunDriver)
:iagree:
Old Sep 7, 2003 | 05:47 AM
Shylor's Avatar
Shylor
I have yet to install the Hurst in my Z06. Do you hear any of the noise others have talked about?
Old Sep 7, 2003 | 08:47 AM
USARMYTTT's Avatar
USARMYTTT
Default Re: Hurst is in!!! (Shylor)
I only drove it about 20 miles after install but I DID NOT hear any added noise.
Old Sep 7, 2003 | 08:58 AM
AFVETTE's Avatar
AFVETTE
I too have a broken boot collar. Good luck finding an un-broken one. Buying a new boot from Ken is a great idea (I have one too) but it doesn't come with a new collar. You can buy a new OEM boot and collar as an assembly from GM but that's like $50. I super glued a small strip of plastic over the broken joint and so far it's holding.
Consider doing the tennis ball mod. Cut a tennis ball in half drill a hole in the center (slight smaller then the largest portion of the lever) then slip it down over the shift lever. It will further quiet any driveline noise.
Good luck with the collar but lose that OEM boot ASAP it looks cheap compared to a Ken King short shifter boot.
Tom
USAF Retired
Old Sep 7, 2003 | 09:27 AM
USARMYTTT's Avatar
USARMYTTT
Default Re: Hurst is in!!! (AFVETTE)
Thanks AFVETTE, I might have to try to do a fixer upper on the ring. Did you have alot of noise????
Old Sep 7, 2003 | 09:47 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Never thought I'd like but it works great no noise either and I got it from LGM with a hardbar ****.
Old Sep 8, 2003 | 12:12 AM
MagRed01Atty's Avatar
MagRed01Atty
Hey,
Maybe you can help me. I recently installed a performance short throw, adjustable shifter and was very disappointed. It was so stiff that i wore a hole in my palm just shifting. I even cut the springs to try and reduce the stiffness. Is this the case with the Hurst? please describe the feel so that I can decide on a replacement. I really like the ball and joint feeling of the stock shifter (no springs) but hate the long throw. What is out there that will give you short throw and great smooth feel? thanks.
Old Sep 8, 2003 | 01:05 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: Hurst is in!!! (MagRed01Atty)
:withstupid: Did you try the different shift stop springs? This will change the feel. You can also try a search for modifying the stock shifter. Someone had an excellent write-up on this not that long ago.
Old Sep 8, 2003 | 01:49 AM
Shylor's Avatar
Shylor
The 2003 shifter boot is cheap...it's vinyl! I'd rather have a rubber boot than a vinyl one.
So where do you get this Ken King short shifter boot and how much?
Old Sep 8, 2003 | 07:03 AM
USARMYTTT's Avatar
USARMYTTT
reply to last three posts:
I left in the stock springs, I don't think it is hard to shift. Is it stiffer..yes, but I would call it more precise.
Again, left in stock springs.
For the Ken King boot, go to the left of the screen to the vendors under"intereior", his company is called Vette Essentials...AWESOME products. Met him in Carlisle and he is a nice guy too.
To Hurst is in!!!
