What is code P1652 on 2001 Z06??
Old Sep 6, 2003 | 11:47 PM
01c5z06's Avatar
01c5z06
Default What is code P1652 on 2001 Z06??
I have a current P1652 on my Z06. anybody know what it is??/ I used tech 2 yesterday to reprogram BCM for tire pressure sensors. Iadded but haven't installed sensors yet. Would this throw the code/
thanks
Old Sep 7, 2003 | 12:11 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: What is code P1652 on 2001 Z06?? (01c5z06)
As per the service manual;
Ensure that the vehicle is equipped with electronic suspension control (ESC). This DTC sets when the body control module (BCM) is programmed if the regular production option (RPO) for the ESC is selected as active and the vehicle is not equipped with ESC.
Did you activate ESC by mistake??? You dont chage BCM RPO's to activate the low tire sensors,it is done through the BCM RFA menu on the TECH2...
