Eradispeed Rotors Warped?
Old Sep 7, 2003 | 01:35 PM
02electronblue's Avatar
02electronblue
Default Eradispeed Rotors Warped?
Has anyone had problems with their Eradispeed rotors warping. I'm getting alot of pulsating during stopping. My rotors have about 15 thousand miles on them. I double checked to make sure there on the correct side and they are. No stress cracks that I can see. Normal driving only. Any help would be appreciated. Also I have stock pads. :cheers:
Old Sep 7, 2003 | 08:41 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Eradispeed Rotors Warped? (02electronblue)
When you installed them, did you season them>
Old Sep 7, 2003 | 11:01 PM
02electronblue
Yes I seasoned them per Baer's instructions. :flag
Old Sep 7, 2003 | 11:05 PM
CHJ In Virginia's Avatar
CHJ In Virginia
No problems with my Eradispeed rotors here. Have run them 25K miles and to MANY autoX and drag events.
Old Sep 8, 2003 | 12:17 PM
beckel's Avatar
beckel
I'm no expert but let me offer the following.
1. Did you check the calipers for lube, resiliency, and movement ?
2. Did you check bearings for free play ?
3. Did you check torque of lug nuts ?
4. Did you check rotors for thickness tolerance and runout tolerance ?
5. Is it possible that the pads are glazed or worn unevenly ?
6. What type of vibration are you feeling ? Is it in the steering wheel or does it feel like rotational skipping
7. As someone else already mentioned, did you season the rotors/pads ?
8. Did you panic stop in the near past ?. If you did, it would be wise to inspect the braking system as suggested above, or find a competent mechanic to diagnose it for you.
Good Luck
Old Sep 8, 2003 | 12:50 PM
02electronblue
Default Re: Eradispeed Rotors Warped? (beckel)
Beckel, Yes I did torque the lug nuts. I'm hoping the pads are glazed. The vibration isn't in the steering wheel. It feels like rotational skipping to me. I did season and bed rotors the pads. The calipers seemed to move freely when I installed the new rotors 15 thousand miles ago. Yes one panic stop recently but the car already had the vibration. Thanks in advance for any information. :cheers:
Old Sep 8, 2003 | 01:21 PM
tboneinsc's Avatar
tboneinsc
No problems with my EradiSpeeds after 10K including autocrossing and drag racing.
Old Sep 8, 2003 | 05:26 PM
Killrwheels's Avatar
Killrwheels
Default Re: Eradispeed Rotors Warped? (tboneinsc)
I have similar problem with mine, and Baer blamed it on the pads and some buildup, then my wheel cleaner, and finally ceramincite (sp). Dealing with rick at Baer so shoot him an email specifically. RickE@baer.com
Basically he told me to tighten/torque the lugnuts and re-season the rotors with 4-6 panic stops from 70 to 35 mph in quick session.
It goes away for 'bout 1000 miles and then seems to be more noticable. http://www.stoptech.com/whitepapers/...otors_myth.htm
I am hoping its warped or glazed pads and look forward to changing soon also. Car has never seen track and running on original pads.
Old Sep 8, 2003 | 06:18 PM
BlueDragon's Avatar
BlueDragon
Default Re: Eradispeed Rotors Warped? (Killrwheels)
I am on my second set of eradi's and I do race. man that is a lot of beef to warp, I don't think it is that. Also change you brake fluid, you may have some moisture in it. Bleed them real well. Could be the pads. What kind do you have? Not sure if I seen it above but did you check run-out? Also too much grease in the sliders on the calipers will cause them to freeze up. Sort of a Vacuum lock.
Jer
Old Sep 8, 2003 | 06:29 PM
QWKAZEL's Avatar
QWKAZEL
Cruise-In III Veteran
I had problems with one of the rears squeeling after about 30 mph. I called Baer and he told me to check if the hand brake pad was rubbing the inside of the rotor and it was. I turned the little wheel so that hand brake pads were all the way closed. That worked, no more noise......
Old Sep 9, 2003 | 01:18 PM
02electronblue
Default Re: Eradispeed Rotors Warped? (BlueDragon)
Blue Dragon, What do you mean by run out? I'm using the stock pads but I'm looking to change any suggestions. :cheers:
To Eradispeed Rotors Warped?
