Plug wire question...
Old Sep 7, 2003 | 09:07 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Default Plug wire question...
Hey guys, what plug wires should I get? I'm gonna replace the plugs w/NGKs, but was trying to decide between MSDs, GM hi-performance, and just stock replacements. I know the MSDs are about $80, the Hi-po Gms are maybe $70, but what are the stocks rated at? What kind of a price could I get from gmpartsdirect vs. the dealer? I don't need anything fancy, but do not want any radio interference. Any opinions are appreciated :cheers:
:smash: Ride On :seeya
Old Sep 7, 2003 | 11:38 PM
ILVET's Avatar
ILVET
St. Jude Contributor
Default Re: Plug wire question... (magnetized)
Im going with the Taylor Spiro pro 8mm wires. Ive heard alot of good things about them and Thunder Racing has them at $42.00 for the set.
Old Sep 7, 2003 | 11:52 PM
KRK's Avatar
KRK
I have MSD's & NGK TR55ix. Definiteley runs smoother, no complaints.
MSD's - http://www.expressautoparts.com part# 32819 $44.73 + shipping
NGK's - http://www.rockauto.com part# 7164 $6.22/ea + shipping
Old Sep 8, 2003 | 08:20 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
I've got MSD's & NGK plugs. I'm very happy so far.
Old Sep 8, 2003 | 01:23 PM
SEAMOORE's Avatar
SEAMOORE
GM high performance and NGK's TR55-IX worked great for me plus you can use your stock heat shields. Bought the wires thru GMpartsdirect for $48 to my front door.
Old Sep 8, 2003 | 01:32 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Plug wire question... (Hildy)
I use the Taylor Thunder Bolts 10mm bad boys and there's no radio interference. I had MSD before these andthey were good plug wires also but I would have to give the edge to the taylors.
:thumbs: :cheers:
Old Sep 8, 2003 | 05:41 PM
c5freak's Avatar
c5freak
Default Re: Plug wire question... (LittleBoyBlu99)
I guess I'm a little different. I'm using Magnecor 8.5 mm wires.
About $100 for the set. Like them so far but it's only been 1 week since the swap.
Old Sep 8, 2003 | 06:15 PM
blktie8's Avatar
blktie8
http://www.magnecor.com
get the KV85 FOR HEADERS
angled boot.
Old Sep 8, 2003 | 09:47 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Plug wire question... (blktie8)
Negative:
Run what the pros run, MSD. They are the best wire on the market w/ no gimmicks (ground straps, 486 layers of silicone, etc). Heads-up, you can order the wires from autozone for $60.00. Ha Ha, no shipping and it's quicker! :thumbs:
Old Sep 9, 2003 | 07:51 PM
AZGASSER's Avatar
AZGASSER
Default Re: Plug wire question... (lowdowndirty)
Any tricks or advice on changing the wires/plugs? Looking to do this in the next few weeks! TIA!
Old Sep 9, 2003 | 08:53 PM
lowdowndirty
Default Re: Plug wire question... (AZGASSER)
It's very straight forward.
Pull off all of your wires. Tip: twist the boot while still on the plug. This will make it easier to remove the wires. You can purchase a plug boot puller from any parts store for cheap. This will help reaching and twisting the boots.
Remove your plugs either w/ a plug socket (w/ the retarded rubber hose piece in it) or a similar socket.
Gap the new plug with a feeler guage.
SNUG the new plug. DO NOT OVERTIGHTEN. It is up to you whether you use anti-sieze. I advise using a very small amount and be careful overtightening, as the anti-sieze will make it easier to accidentally do so.
Install your new wires, making sure you feel them snap onto both the plug and the coil. If you use MSD or a similar wire, do not reuse the factory heat sheilds. When using a Delco/Delphi wire, reinstall the sheilds on the new wires before you install them.
A little long-winded but I don't know your experience with turning wrenches.
Good luck. :yesnod:
[Modified by lowdowndirty, 1:55 AM 9/10/2003]
To Plug wire question...
