Car won't shift from Park, HELP.
Old Sep 7, 2003 | 11:02 PM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Car won't shift from Park, HELP.
From time to time, my A4 doesn't want to come out of park. Its like the brake before shift lock doesn't know I am pushing the brake down. Some times I have to wiggle the crap out of it for 15 seconds or so for it to go.
Anyone have advise on how to correct this, and/or if I can bypass the brake before shift lock feature without throwing any codes? Somone once said to unplug and replug some connector, but I'm not sure which one and how that is supposed to do anything?
Old Sep 7, 2003 | 11:06 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Car won't shift from Park, HELP. (TexCorvette)
Just a wild guess, but does it happen when parked on a hill? If so it may just be "torque lock" (pre-loading on the drivetrain).
Old Sep 8, 2003 | 12:05 AM
Aheash's Avatar
Aheash
Default Re: Car won't shift from Park, HELP. (lowdowndirty)
I was wondering about that, too.
Old Sep 9, 2003 | 08:47 AM
TexCorvette
Default Re: Car won't shift from Park, HELP. (Polaris)
Not really. I was thinking about that also, but mostly in my garage, which is level. It also only does it if the car sits for a day or more. It gives me a hard time when I first pull it out, but hen generally, its ok the rest of the day. I think it has something to do with the brake before shift mechanism I want to just disable!
Old Sep 9, 2003 | 01:25 PM
CJ454's Avatar
CJ454
Cruise-In II Veteran
May be you should drive it more. It might be lonley and getting even with ya for not take it out more often. :D :jester
CJ :steering:
Old Sep 17, 2003 | 08:04 AM
TexCorvette
Default Re: Car won't shift from Park, HELP. (CJ454)
Anyone else have this issue? Don't feel like having the dealer rip my car apart. :smash:
Old Sep 17, 2003 | 09:21 AM
Fast one's Avatar
Fast one
Check the archives, it's been in here before.
Old Sep 17, 2003 | 09:43 AM
lotzahp's Avatar
lotzahp
do you have brake lights?
The switch at the back of the brake pedal senses if the pedal is depressed. If it is not, you won't have brake lights AND the computer will not allow you to shift out of park.
The switch may also be intermittent.
Old Sep 17, 2003 | 10:00 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
Some systems I just wouldn't want to mess with. I think the brake before shift out of park is one of those. Hopefully it is just a switch and you'll be good as new.
Old Sep 17, 2003 | 06:23 PM
TexCorvette
Default Re: Car won't shift from Park, HELP. (C5 StockSwap)
What was posted here long ago wasn't very detailed, about unpluging and repluging something? :(
I will check for brake lights, but I'm sure they work. This and the steering sensor eoor are the only things getting on my nerves with this car right now.
Old Sep 18, 2003 | 09:23 AM
Fast one's Avatar
Fast one
If you take off the console the lockout solenoid and connector are available to check voltage and movement, the small key lockout cable is also there so it can be disconnected to verify correct operation.
Old Sep 27, 2003 | 09:31 AM
TexCorvette
Default Re: Car won't shift from Park, HELP. (Fast one)
Can I bypass the lockout without any other issues or codes? This is really becoming a PITA for me. :mad Today it took 8 minutes to get it into Reverse to leave the garage.
To answer one of the other posts, my brake lights do come on, and it does happen when the car is level.
[Modified by TexCorvette, 9:33 AM 9/27/2003]
To Car won't shift from Park, HELP.
