Neebie question about ecu
Old Sep 8, 2003 | 04:13 PM
eurovette's Avatar
eurovette
3rd Gear
Default Neebie question about ecu
Hey Guys !
I'm new at this forum and I need some help!
My 2002 C5 is in hungary and needs a new computer,But I don't know which one .What I know that this one is located under the glove box , inside the car and on the top says DHSY!Big silver box and includes the PROM ,what is screwed, but I want the whole box !
The dealer needs to know which one is this ,bc he doesn't know by the location of the box!
Thanks for your help!
Lajos :confused:
[Modified by eurovette, 9:15 PM 9/8/2003]
Old Sep 8, 2003 | 08:43 PM
markcz's Avatar
markcz
Default Re: Neebie question about ecu (eurovette)
The 'computer' you're talking about is the BCM (Body Control Module). The part number for a 2001 BCM is 10304931. Look at the pic below to see the location of the part number on the sticker of my 2001 BCM, then get the correct number off of the sticker from your 2002 BCM (they MIGHT be the same, but don't chance it). You can probably get the number from the parts dept. of a local dealer to confirm it. GMpartsdirect.com has it for $167, so don't let them screw you on the $. Good luck.
:cheers:
edit: click on the pic to supersize it so you can read the sticker
[Modified by markcz, 8:44 PM 9/8/2003]
Old Sep 8, 2003 | 09:20 PM
eurovette's Avatar
eurovette
3rd Gear
Thanks a lot!
:cheers:
Does anybody know by any chance what is the part number for the 2002 c5 coupe BCM (Body Control Module).
Thanks again !
Lajos
[Modified by eurovette, 2:21 AM 9/9/2003]
To Neebie question about ecu
