End link removal/install question
Old Sep 8, 2003 | 05:16 PM
C6~Missle's Avatar
C6~Missle
Default End link removal/install question
I had the car on ramps today as I was changing the oil. I recently bought some aluminum end links to replace the plastic ones used on my FRC in the rear.
I used an 18mm wrench on the nut. When I turned it, it also turned the shaft so I could not loosen the nut. I tried to put the wrench on the inside of the endlink to see if it would fit, but it was too thick, so I had to leave them for now.
Any tips on removing these..
mike
Old Sep 8, 2003 | 05:21 PM
jmzvet's Avatar
jmzvet
Default Re: End link removal/install question (C5~Missle)
You need to use a Torx wrench to hold the bolt from turning while you turn the nut. I don't know what size Torx. :cheers:
Old Sep 8, 2003 | 05:26 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: End link removal/install question (jmzvet)
:iagree:
T-40 to get the old plastic ones off, Hex wrench or 18mm end wrench to tighten the metal ones on. Reuse the nuts.
http://www.ls1howto.com/index.php?article=16
[Modified by Umrswimr, 4:27 PM 9/8/2003]
To End link removal/install question
