deciphering LTFT and others
Old Sep 8, 2003 | 08:03 PM
corvette184's Avatar
corvette184
Default deciphering LTFT and others
i recently installed a predator programer and her are some of my numbers on a 70degree day at around 60mph rpms 2000 can anybody help explain what the numbers mean......short = +2.0 thru +3
long = +9.3 thru +10.0
short = -3.0 thru +1.0
long = +10.0 thru +14.0
m a p = 4.9 thanks
Old Sep 8, 2003 | 08:04 PM
corvette184
Default Re: deciphering LTFT and others (corvette184)
ps these numbers are very close to actual...i was driving and writing ...they fluctuate a bit
Old Sep 8, 2003 | 08:15 PM
jawsski's Avatar
jawsski
m a p = 4.9 thanks
You're running lean..nice to be just above 0...around +2/+3
map= manifold air pressure... looks ok
[Modified by jawsski, 8:16 PM 9/8/2003]
Old Sep 8, 2003 | 08:18 PM
corvette184
Default Re: deciphering LTFT and others (jawsski)
if i adjust the fuel on the predator wont it also affect my short readings?????
Old Sep 8, 2003 | 08:38 PM
corvette184
is this dangerously lean......
m a p = 4.9 thanks
Old Sep 8, 2003 | 08:40 PM
chuckster's Avatar
chuckster
Don't pay attention to the STFT's
YOur LTFT's are WAY lean....you need to add more fuel... You really want your LTFT's to show -1 to -5 Which is a good range.. The reason it's better be negative is that when you go WOT (PE) mode you won't be adding the extra fuel that the LTFT's were trying to add.. As long as they are negative you just get the fuel that is in the WOT table..
I don't know how the predator programs more fuel.. But with LS1edit it is best to change the injector pulse to make it a tad richer..
Old Sep 8, 2003 | 08:49 PM
jawsski's Avatar
jawsski
Default Re: deciphering LTFT and others (chuckster)
[QUOTE]Don't pay attention to the STFT's
You really want your LTFT's to show -1 to -5 Which is a good range.. The reason it's better be negative is that when you go WOT (PE) mode ....QUOTE]
This is OK if you are going to WOT often..and I mean very often like on the track...for a daily driver the car will not have that SOTP pep at lower rpm unless you are slightly lean ..ALSO...running that rich you will get soot all over the butt end :nonod:
Old Sep 8, 2003 | 08:52 PM
jawsski's Avatar
jawsski
No you're Ok..you get this by just changing to a Blackwing.
Old Sep 8, 2003 | 09:21 PM
corvette184
i just uninstalled the predator program and my numbers came back down to +1thru+5.... and i can feel the tires activate traction control again....at about 4300rpm.....i think i will avoid using the predator....i can still watch my nubers with it tho.....thanks for the help guys......ps mods are halltech t1-c,stainless works headers and a shaner t/b......i am going to the dyno monday and i will get some real numbers then hook up predator again and compare :party:
Old Sep 9, 2003 | 07:42 AM
chuckster's Avatar
chuckster
Dude, trust me..
You want your LTFT's negative.. Even if you don't spend a lot of time at WOT..
The LS1 performs better when the PCM is Pulling fuel (Negative) to achieve Stoich conditions.
If you have positive LTFT's when the PCM goes to WOT, that extra fuel gets added to the PE value.. this makes it difficult to tune because that value changes.
If you have negative LTFT;s when the PCM goes to WOT, the trims will LOCK out to 0 and ONLY the fuel value in the PE table will be used.
That being said, the Predator is a poor tool to make really good LTFT and PE changes. LS1edit rules... ;)
Old Sep 9, 2003 | 08:51 PM
jawsski's Avatar
jawsski
Charlie, Never mind,, I misread your thread
[/QUOTE]The LS1 performs better when the PCM is Pulling fuel (Negative) to achieve Stoich conditions.
[/QUOTE]
[Modified by jawsski, 8:57 PM 9/9/2003]
Old Sep 10, 2003 | 06:14 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
The STFT (Short Term Fuel Trim) can be seen as the instaneous value the sensors are reading and the LTFT's (Long Term Fuel Trim) are the learned valued. The STFT's are continually averageaged into the LTFT's. When the LTFT's are reset to 0 the STFT's will read very high initially and as the LTFT's begin to average and normalize thee STFT will approach 0. This process then repeats itself for all of the fuel cells that you encounter. Once the STFT's are reading consistantly low in all fuel cells we can say the has finished learning.
So yes, the STFT's do have some relevance to understanding what is happending with the LTFT's.
Old Sep 11, 2003 | 01:48 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: deciphering LTFT and others (Godspeed)
Jeremy, I use EFILive and one of the PID's that is available is a LS1 specific STFT Average. I have started watching this since it changes slower than the STFT, but faster than LTFT.
Normally when I see a positive or negative STFT Average it will eventually change the LTFT in that cell and reset the STFT Avg to zero.
Eric
To deciphering LTFT and others
