Cooling Fan Questions
Old Sep 9, 2003 | 03:45 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
Default Cooling Fan Questions
At what coolant temperature should the cooling fan kick on? Also, do both fans run with the AC on?
TIA!
Old Sep 9, 2003 | 03:58 PM
C7GrandSport's Avatar
C7GrandSport
Default Re: Cooling Fan Questions (Doughan)
No, only one fan comes on with A/C. The other doesn't come on until things get pretty hot! So you may want to reprogram your fans to turn on sooner. You can do this yourself with the hand held programmers, or better yet, spend a little bit more and haver a qualified tuner use LS1 Edit to custom tune the car for you. This is not a real expensive proposition, but will give you pretty nice results.
Old Sep 9, 2003 | 04:42 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Low speed fans come on at 226-228 depending on model year.High speed fans come on at 235...Both fans come on with the A/C on :yesnod:
Old Sep 9, 2003 | 04:46 PM
Doughan's Avatar
Doughan
Elite Member
Default Re: Cooling Fan Questions (C-5 TECH)
Thanks for the info! :cheers:
To Cooling Fan Questions
