Hi all,
My oil pressure guage was registering the pressure pegged at 80 PSI on the way home tonight. I parked it and restarted thinking it was a malfunction of the sensor, but it quickly climbed back up to 80 PSI right after I restarted the car. Any ideas?
Very common problem,,,Oil pressure sensor is bad... cost 35 dollars... the intake has to be removed... dealer charge 150 dollars... have seen atleast a dozen people pots tis problem in the last two weeks.. Job takes about an hour Ive done two of them..
