Competitive Driving?????
Old Sep 11, 2003 | 09:40 AM
dallasvette's Avatar
dallasvette
Default Competitive Driving?????
I did look in the instruction manual. but can someone explain this to me?
thanks
Old Sep 11, 2003 | 09:41 AM
dallasvette
Default Re: Competitive Driving????? (dallasvette)
Old Sep 11, 2003 | 09:53 AM
wamara's Avatar
wamara
Cruise-In II Veteran
The competitive driving mode disables the traction control, but the active handling function remains operational.
Old Sep 11, 2003 | 09:56 AM
Skull One's Avatar
Skull One
thanks
Simply put, from a driving test I did on my '04 yesterday, you get a little more wheel spin and play in turns. I.E. you can slide a turn better without the safety systems kicking in instantly. But hey, I have only had the car 13 days and I am still learning it :)
Old Sep 11, 2003 | 10:14 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Competitive Driving????? (wamara)
:iagree: :iagree:
Old Sep 11, 2003 | 10:26 AM
00TORCHCOUPE's Avatar
00TORCHCOUPE
Default Re: Competitive Driving????? (ICULUKN-C5)
:iagree: :iagree:
:iagree: :iagree: :iagree: Allows you to spin tires in straight launches and helps control sliding in turns by braking to compensate. The traction control will actually cut out the throttle, the active handling will not (at least my experience). I am not a great driver yet, so during autocross I run in competitive mode.
Old Sep 11, 2003 | 10:57 PM
C7GrandSport's Avatar
C7GrandSport
Default Re: Competitive Driving????? (00TORCHCOUPE)
It deactivates traction control so it doesn't reduce the throttle when wheel spin is detected so you can have more fun in a straight line. But it keeps active handling on to make correction if you try to do something stupid.
Old Sep 12, 2003 | 12:48 AM
HawkIVette's Avatar
HawkIVette
Got it straight yet? If not, one more time:
Active Handling/Traction Control
Active Handling= computer controls wheel slippage by appling the brakes.
Traction control= computer controls wheel slippage by reducing throttle responce.
Active Hand/ Traction Cont. off= both off
Active Hand./ Traction Cont. on= both on
Competative Driving Mode = Traction Cont. off and Active Handling on
Old Sep 12, 2003 | 11:42 AM
steveo F76's Avatar
steveo F76
Default Re: Competitive Driving????? (c5grandsport)
How do you set it for Competitive Driving mode ?
Old Sep 12, 2003 | 11:53 AM
HawkIVette's Avatar
HawkIVette
Default Re: Competitive Driving????? (steveo F76)
Press and hold the AH/TC button down for about 6 sec. or so.
Old Sep 12, 2003 | 01:09 PM
SeattleC5's Avatar
SeattleC5
The car is definitely more entertaining with the competitive mode enabled.
However, the downside to having the competitive driving mode on is the information center will only display this as a message, so you can't check your other digital information. I guess this is a safety precaution to keep you from forgetting it's set on competitive mode.
Old Sep 12, 2003 | 01:33 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Default Re: Competitive Driving????? (SeattleC5)
:nono: Hit the Reset button on your DIC. The message goes away. But, the icon in the cluster stays on as a reminder.
Save the WAVE!! :seeya
To Competitive Driving?????
