clutch life?
Old Sep 11, 2003 | 02:45 PM
tk97's Avatar
tk97
Default clutch life?
I think the life of my clutch on my 97 coupe is coming to an end. I have just over 56,000 miles on her, and the clutch is starting to show signs of slipping. When I upshift or downshift at high rpms it doesn't fully engage and the pedal doesn't come up all the way, possible throwout bearing? However, I've read some previous posts about the same issue and have seen some members mention that the computer can electronically control the clutch engagement if it feels that the clutch is beginning to slip, or if there is any potential damage to the rest of the drivetrain. Is there any truth to this, or does the clutch just need to be replaced?
Old Sep 11, 2003 | 04:24 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: clutch life? (tk97)
________________________________________ ________________________
I assume your car is a 6-speed. If so, the computer has nothing to do with it. I would suggest that you first have the clutch bleed before you go for the big bucks of a new one. 56,000 miles isn't extreme milage, unless of course, you beat the hell out of it on a constant basis. The slave cylinders do become pretty funky (fluid gets dirty and contaminated) maybe a good bleeding is all it needs.
Old Sep 11, 2003 | 05:13 PM
tk97's Avatar
tk97
Default Re: clutch life? (vette#one)
Thanks for advice! I don't beat on my car, but I do like to have fun with it once in a while. This problem only happens when the clutch and tranny are running really hot.
thanks again
To clutch life?
