Kumho Tire ??????
Old Sep 11, 2003 | 08:41 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Kumho Tire ??????
Is it feasable to run Kumho MX 255-35-18 up front and 275-35-18 Kumho MX on the rear or is there too much of a difference?
Old Sep 11, 2003 | 11:18 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Kumho Tire ?????? (1SGRET)
Get out your pencil and do some calculations, this should help!
http://www.miata.net/garage/tirecalc.html
Old Sep 12, 2003 | 07:40 AM
1SGRET's Avatar
1SGRET
Default Re: Kumho Tire ?????? (wallstAL)
Thanks for the neat program.
Old Sep 12, 2003 | 07:32 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
*** Hole? :rofl:
Tom
Old Sep 12, 2003 | 08:01 PM
Face's Avatar
Face
Default Re: Kumho Tire ?????? (TCW)
*** Hole? :rofl:
Tom
:confused:
Old Sep 23, 2003 | 03:24 PM
jeffjor's Avatar
jeffjor
I am running 265/35zr18 in front and 295/35zr18 in back on 18x9.5 and 18x11 rims. No problems. Just had the speedo recalibrated to read correctly.
You should really like the MXs. I use them on the street and the track.
Old Sep 23, 2003 | 04:10 PM
connellyh's Avatar
connellyh
Before I went to 275-35 on 18X10's up front and 335-30 on 18x12's in back, I ran the stock '99 rims with Kumho Ecsta 712 245-40's up front and 275-35 in back. The speedo was a bit off, in read over by 3 mph @ 60. If you have access to a programmer, you can easily adjust the speedo. 255's up front will be fine. Their might be a little more hunt and wander, depending on pressures and alignment.
Old Sep 23, 2003 | 06:57 PM
XTrooper's Avatar
XTrooper
The Kumho MXs are AWESOME and their cost is unbelievably low! :thumbs:
To Kumho Tire ??????
