I recently installed a hurst shifter and used the bottom bushing (the black fiber cup) from the factory shifter. I have now read you should replace it . Has anyone replaced it and if so where did you get it. My local chevy dealer said the part was not listed (which I doubt). I am having trouble hitting 3rd on fast shifts. It seems to be a little out of alignment and hangs up between going into 3rd and 5th.
The directions that came w/ the Hurst said use the one from the stock shifter and I've never heard of anyone replacing it
as for the part not being listed, it really doesn't suprise me. Either the guy at the dealership is being lazy (very common) or chevy only sells it with the complete shifter unit (I had to buy a whole passanger side mirror for the pins that connect the motor to the mirrior :banghead: )
