Powerloader or Hypertech??
Old Sep 12, 2003 | 07:42 PM
V-tail pilot's Avatar
V-tail pilot
Cruising
Default Powerloader or Hypertech??
I recently purchased a 1999 M6 that needs to have the running hot problem corrected (fans need to come on earlier). I drive this car 2-3 days a week so a radical performance gain is not necessary. I notice engine ping under tip-in when above 205' (I saw a link somewhere about the decarboning procedure but lost it so someone help me here) so I'm a bit leary about a big timing advance boost- assuming the decarbon won't take care of the ping. Hypertech appears to have t-stat options that Powerloader does not have so I'm leaning toward Hyper. Both options tout the improved shifting of the automatic but I would like to hear from the M6 owner's about the cooling system improvements. Also is anyone else getting the pinging at 230' on tip-in??? Seems half the crowd is content with running hot but they must not be getting the detonation.... :steering:
Old Sep 12, 2003 | 09:17 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Powerloader or Hypertech?? (V-tail pilot)
get LS1 edit.
Poke around this forum... http://forums.corvetteforum.com/zeroforum?id=91
[Modified by SHOWTIME!, 6:18 PM 9/12/2003]
Old Sep 12, 2003 | 10:06 PM
O-Ace's Avatar
O-Ace
Neither; go with LS1 Edit. I went with the PowerLoader first, and then got LS1Edit later. Save the money, and do it right the first time :cheers:
Old Sep 12, 2003 | 10:13 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Powerloader :rofl: :lolg: :lol: A BIG JOKE!!!!!!!!!!!!!!!!!!!
DO NOT waste your money!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! Whatever you do DO NOT buy the Powerloader! :lol: Your car will be SCREWED!!!!!!!!!!!!!!!!!!!!!!!!!!
Get LS1Edit by a tuner.
Old Sep 12, 2003 | 10:53 PM
ndirishr1's Avatar
ndirishr1
I bought my wife a 2000 Automatic and the previous owner had done a Hypertech. I have since deprogrammed and then reprogrammed it. Hypertech is very easy to use and fun to play with. I haven't used the Powerloader.
Old Sep 13, 2003 | 02:18 AM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Powerloader or Hypertech?? (Buckmaster)
I got loaded b4 there was LS1 edit and it still works fine :confused:
Old Sep 13, 2003 | 02:36 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Just because a lot of people are down on the customer service, the Powerloader is still a great program. I have no complaint at all! :yesnod: :yesnod: :yesnod:
Old Sep 13, 2003 | 10:40 AM
YO-EL's Avatar
YO-EL
Default Re: Powerloader or Hypertech?? (wallstAL)
Is the PL still being sold?
Old Sep 13, 2003 | 11:02 AM
nmbis2k's Avatar
nmbis2k
Al - do you know of a good tuner in So Cal?
Old Sep 13, 2003 | 11:42 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Powerloader or Hypertech?? (nmbis2k)
I do not know, call TTS.
None that I would recommend!
Old Sep 13, 2003 | 12:04 PM
BlackSun!'s Avatar
BlackSun!
I got a powerloader I will sell CHEAP!!!! :yesnod:
Old Sep 13, 2003 | 12:32 PM
MTWallet's Avatar
MTWallet
Default Re: Powerloader or Hypertech?? (BlackSun!)
Pro's & Cons...
LS1 Edit
[Pro] -You can change ANY variable in the PCM you want, whenever you want. :thumbs:
[Con] It costs a bit more and is a little more complicated than the others.
Hypertech
[Pro] - You can change any of the variables that it lets you change whenever you want to suit your particualr needs. Easy to use.
[Con] - You are limited as to what can be changed.
TTS Powerloader
[Pro] - You have a custom program created and loaded in a small box. You plug it in, let it download and you're done.
[Cons] -
#1 Its expensive
#2 You have to send the box back to them to have any changes made to your program.
#3 You have to pay a fee for any changes to the program.
#4 You never know if or when you will ever get you box back.
#5 You can never reach anyone at TTS for tech help.
#6 It locks your PCM so you can't use LS1 Edit on it until you get it re-flashed at the dealer. :bs
#7 Its obsolete! :hurray:
[Modified by MTWallet, 11:40 AM 9/13/2003]
Old Sep 13, 2003 | 01:03 PM
geekracer's Avatar
geekracer
I started out with the Hypertech and switched to LS1Edit when it became available. If you're looking for a tuner "in a box" then I would go with the HP3 because you can revert to stock programming and then sell it later. Note that the box tuners will give you a fixed tune and that is all you get. For example if you just care about lowering your fan turn on temps then I would get a cheap used HP3 for your model year.
If you want to really tune your car then you need LS1Edit and at least autotap to monitor the performance of the engine. Tuning is a continuous process of doing research, making small changes and measuring the results. :thumbs:
Old Sep 13, 2003 | 01:15 PM
fdxpilot's Avatar
fdxpilot
You need to start learning this site. The decarb procedure is in c-5 tech tips, under the tools menu at the top of the page. :chevy
Try this:
https://www.corvetteforum.com/techti...=212&TopicID=1
BTW - Got youself a "doctor killer", Huh? :lol: :chevy
Old Sep 13, 2003 | 01:16 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Powerloader or Hypertech?? (MMarquez)
I would go w/ the LS1 edit. I made 25 rwhp and 30 ft/lb of tourqe just from edit and they work my fans and rev limiter. I am very happy w/ what they did. It only cost me $350 bucks at Dragon race in Broomfield, Colorado. Kaley
Old Sep 13, 2003 | 01:35 PM
SFVetteman's Avatar
SFVetteman
If your not interested in the power programming aspects then I would go with a Hypertech but get a used one (make sure it's programmed back to stock) for a fraction of the price. After you do the decarb and lower your fan temps your pinging should go away. You might also consider a lower temp thermostat to go with the lower fan temps.
If you wanted a progammer that would increase your power then while LS1 edit is the best it also means you'll be in for a bit of a learning curve. You would probably be happier with a Diablo Sport Predator.
Old Sep 13, 2003 | 02:29 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Powerloader or Hypertech?? (SFVetteman)
I never would ahve gotten a powerloader if LS1 Edit had been available WAYYYYY back when.....
To Powerloader or Hypertech??
