How do I identify a MN6 vs MN12 trans ?
Old Sep 13, 2003 | 10:52 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default How do I identify a MN6 vs MN12 trans ?
I would like to know what numbers to look for or what I need to know to tell them apart out of a car.
TIA.. :cheers:
Old Sep 14, 2003 | 11:45 AM
RPO_Z06's Avatar
RPO_Z06
Default Re: How do I identify a MN6 vs MN12 trans ? (RPO_Z06)
ttt.. Someone knows this don't they ? :steering:
Old Sep 14, 2003 | 12:46 PM
mapman's Avatar
mapman
I would like to know what numbers to look for or what I need to know to tell them apart out of a car. ....
Don't know about numbers, however the gear ratios are:
Gear - MM6 (:1) --- M12 (:1)
First -- 2.66 : 1 ---- 2.97 : 1
Sixth - 0.50 : 1 ---- 0.57 : 1
Old Sep 14, 2003 | 12:58 PM
Brian@KelleyPerf's Avatar
Brian@KelleyPerf
Probably the easiest way to tell by just looking at it is to look at the rear of the transmission on the drivers side, there will be a 2 conductor connection for the transmission temp sensor that only the M-12 has. On the M-6, this connector does not exist. Do NOT confuse this connector withe the cags connector that both have as well.. Hope this helps...
TIA.. :cheers:
Old Sep 14, 2003 | 02:59 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Default Re: How do I identify a MN6 vs MN12 trans ? (Brian@KelleyPerf)
12561852 on the metal tag is a M12 and the paper tag on top reads DXB :yawn:
Old Sep 14, 2003 | 03:33 PM
RPO_Z06's Avatar
RPO_Z06
Default Re: How do I identify a MN6 vs MN12 trans ? (Crashed 94)
Thanks for the info, that's what I needed to know. :cheers:
To How do I identify a MN6 vs MN12 trans ?
