need help with headlight motor!!
Old Sep 14, 2003 | 05:30 PM
sick_vette's Avatar
sick_vette
Default need help with headlight motor!!
my driver's side head light is struggling to go up. You can hear the motor spinning but it does not go up all the way. When I pull it up. It still keeps spinning. Same as when it goes down all the way. Any ideas what could be wrong? :cheers:
Old Sep 14, 2003 | 06:11 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: need help with headlight motor!! (blackroadster)
The nylon gear is stripped inside the motor :yesnod:
Old Sep 14, 2003 | 06:43 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: need help with headlight motor!! (C-5 TECH)
You Think your so smart...... well you are...
someone here is selling a brass gear for this application.. user name is (mire)
I think they are around 50 dollars... you cant just buy the nylon gear .... you need the whole actuator... cost is around 150 dollars.... You can replace it yourself... either the gear or the actuator... If you are modestly technical.
Old Sep 14, 2003 | 07:23 PM
sick_vette's Avatar
sick_vette
Default Re: need help with headlight motor!! (Evil-Twin)
Thanks alot. I'll pull it apart and see what's going on. :cheers:
To need help with headlight motor!!
